  • Automation Suite on Linux Release Notes
    • 2024.10.0
    • 2024.10.1
    • 2024.10.4
    • 2024.10.5
  • Automation Suite on EKS/AKS Release Notes
    • 2024.10.5
  • Automation Suite on OpenShift release notes
Automation Suite release notes
Last updated Oct 8, 2025
2024.10.5
Release date: September 24, 2025
Enhanced support for Azure backup store configuration in AKS
We have added support for using a storage account access key when configuring the backup store in AKS. This addition provides an alternative to service principal–based authentication, offering more flexibility without affecting existing configurations.
For more details, refer to Providing the backup store configuration.
AI Units usage metrics available in support bundle tool
The Automation Suite support bundle tool now collects AI Units usage metrics if you use AI Center.
Bug fixes
  • We have fixed an issue that prevented log forwarding when using S3 endpoints in non-AWS format (that is, without .amazonaws.com in the URL), as the endpoint was not in the format expected by Fluentd.
  • An issue prevented Velero backups from completing successfully. A FailedValidation error message was displayed, indicating that no default backup location could be found. This issue occurred because Velero could not locate a default backup storage location when the spec.default field was missing in the BackupStorageLocation configuration.
  • We fixed an issue in Integration Service and Orchestrator where outgoing network requests did not respect environment proxy settings. This caused Jira and Slack connections to fail in EKS/AKS deployments with proxy configurations.
Deprecation timeline
We recommend that you regularly check the deprecation timeline for any updates regarding features that will be deprecated and removed.
Bundling details
Product versions
The following table outlines the release status, version, and release notes for all UiPath products deployed under Automation Suite 2024.10.5.
Legend:
available - This Automation Suite version bundles a new version of the product. New release notes are available.
not available - This Automation Suite version bundles a previously released version of the product. No new release notes are available.
ProductProduct versionRelease statusRelease notes
Action Center2024.10.5
available
Action Center release notes
AI Center2024.10.5
available
AI Center release notes
AI Computer VisionN/A
not available
N/A
Apps2024.10.5
available
Apps release notes
Automation Hub2024.10.5
available
Automation Hub release notes
Automation Ops2024.10.5
available
Automation Ops release notes
Data Service2024.10.5
available
Data Service release notes
Document Understanding
available
Insights2024.10.6
available
Insights release notes
Integration Service2024.10.5
available
Integration Service release notes
Orchestrator2024.10.8
available
Orchestrator release notes
Process Mining2024.10.5
available
Process Mining release notes
Studio Web2024.10.5
available
Studio Web release notes
Task Mining2024.10.5
available
Task Mining release notes
Test Manager2024.10.5
available
Test Manager release notes
Internal third-party component versions
For the Kubernetes versions that each Automation Suite version supports, see Kubernetes compatibility.
This Automation Suite release bundles the following internal components:
ComponentVersion
Istio1.26.3
ArgoCD3.0.11
Prometheus3.5.0
Grafana12.0.2
Fluentd and Fluent-bit
logging-operator: 6.0.1
fluent/fluent-bit: 4.0.3
Gatekeeper3.20.0
Cert-Manager1.18.2
Velero10.0.10
