- Overview
- Requirements
- Deployment templates
- Step 2: Configuring the OCI-compliant registry for offline installations
- Step 3: Configuring the external objectstore
- Step 4: Configuring High Availability Add-on
- Step 5: Configuring SQL databases
- Step 6: Configuring the load balancer
- Step 7: Configuring the DNS
- Step 8: Configuring the disks
- Step 9: Configuring kernel and OS level settings
- Step 10: Configuring the node ports
- Step 11: Applying miscellaneous settings
- Step 13: Generating cluster_config.json
- Certificate configuration
- Database configuration
- Kerberos authentication configuration
- Monitoring configuration
- Cluster administration
- Managing products
- Migrating from in-cluster to external High Availability Add-on
- Migrating from in-cluster registry to an external OCI-compliant registry
- Redirecting traffic for the unsupported services to the primary cluster
- Scaling a single-node (evaluation) deployment to a multi-node (HA) deployment
- Monitoring and alerting
- Migration and upgrade
- Step 8: Deleting the default tenant
- Upgrading Automation Suite
- Executing the upgrade
- Using the Orchestrator Configurator Tool
- Orchestrator appSettings
- Configuring appSettings
- Troubleshooting
- How to clear Redis data
- How to enable Istio logging
- How to upgrade from Automation Suite 2022.10.10 and 2022.4.11 to 2023.10.2
- How to forward application logs to Splunk
- How to clean up unused Docker images from registry pods
- Test Automation SQL connection string is ignored
- Data loss when reinstalling or upgrading Insights following Automation Suite upgrade
- RKE2 not getting started due to space issue
- In-place upgrade timeouts
- AI Center provisioning failure after upgrading to 2023.10 or later
- SQL validation fails during upgrade
- Longhorn REST API endpoint upgrade/reinstall error
- ArgoCD login failed
- Redis probe failure
- RKE2 server fails to start
- Pods stuck in Init:0/X
- Failure to configure email alerts post upgrade
- No healthy upstream issue
- Document Understanding not on the left rail of Automation Suite
- Failed status when creating a data labeling session
- Failed status when trying to deploy an ML skill
- Migration job fails in ArgoCD
- Handwriting recognition with intelligent form extractor not working
- Failed ML skill deployment due to token expiry
- After Disaster Recovery Dapr is not working properly for Process Mining
- Configuring Dapr with Redis in cluster mode
- Exploring Logs
- Exploring summarized telemetry
Last updated Nov 13, 2025
When you provide an SQL connection string under the
orchestrator.testautomation section of the cluster
configuration file, the uipathctl binary ignores the connection
string and uses the one under the orchestrator section instead. As
the following sample shows, the ignored connection string is the value of the
sql_connection_str
parameter:"orchestrator": {
"testautomation": {
"enabled": true,
"sql_connection_str": "Server=tcp:new-sql-server-name,1433;Initial Catalog=new-db;Persist Security Info=False;User Id=test;Password='************';MultipleActiveResultSets=False;Encrypt=True;TrustServerCertificate=True;Connection Timeout=30;Max Pool Size=100;"
}"orchestrator": {
"testautomation": {
"enabled": true,
}To address the issue, take the following steps:
Perform a Base64 encoding of the SQL connection string that you provided as the value of the
sql_connection_strparameter:echo -n "<sql_connection_str under orchestrator.testautomation in cluster config file>" | base64 -decho -n "<sql_connection_str under orchestrator.testautomation in cluster config file>" | base64 -d -
Run the following command to edit the
orchestrator-secretssecret:kubectl edit secret orchestrator-secrets -n uipathkubectl edit secret orchestrator-secrets -n uipath -
In the secret, update the value of the
sqlConnectionStringTAparameter with the Base64-encoded connection string value. -
Check if you successfully updated the connection string value:
kubectl get secret orchestrator-secrets -n uipath -o jsonpath="{.data.sqlConnectionStringTA}" | base64 --decodekubectl get secret orchestrator-secrets -n uipath -o jsonpath="{.data.sqlConnectionStringTA}" | base64 --decode -
In the ArgoCD app UI, navigate to Orchestrator > Details > Parameter > Values > Inside values > Update.
Under the
connectionStringssection, update the value of theTestAutomationparameter with the plain-text value of the connection string, as shown in the following sample:connectionStrings: TestAutomation: <Plain-text value of sql_connection_str under orchestrator.testautomation in cluster config file>connectionStrings: TestAutomation: <Plain-text value of sql_connection_str under orchestrator.testautomation in cluster config file>
