- Overview
- Requirements
- Deployment templates
- Manual: Preparing the installation- Manual: Preparing the installation
- Step 2: Configuring the OCI-compliant registry for offline installations
- Step 3: Configuring the external objectstore
- Step 4: Configuring High Availability Add-on
- Step 5: Configuring SQL databases
- Step 6: Configuring the load balancer
- Step 7: Configuring the DNS
- Step 8: Configuring the disks
- Step 9: Configuring kernel and OS level settings
- Step 10: Configuring the node ports
- Step 11: Applying miscellaneous settings
- Step 13: Generating cluster_config.json
- Certificate configuration
- Database configuration
- Kerberos authentication configuration
- Monitoring configuration
- Cluster administration- Managing products
- Migrating from in-cluster to external High Availability Add-on
- Migrating to an external OCI-compliant registry
- Redirecting traffic for the unsupported services to the primary cluster
- Scaling a single-node (evaluation) deployment to a multi-node (HA) deployment
- Monitoring and alerting
- Migration and upgrade- Step 1: Moving the Identity organization data from standalone to Automation Suite
- Step 8: Deleting the default tenant
- Upgrading Automation Suite
- Executing the upgrade
- Product-specific configuration- Using the Orchestrator Configurator Tool
- Orchestrator appSettings
- Configuring appSettings
- Troubleshooting- How to troubleshoot services during installation
- How to clear Redis data
- How to enable Istio logging
- How to upgrade from Automation Suite 2022.10.10 and 2022.4.11 to 2023.10.2
- How to forward application logs to Splunk
- How to clean up unused Docker images from registry pods
- Test Automation SQL connection string is ignored
- Data loss when reinstalling or upgrading Insights following Automation Suite upgrade
- RKE2 not getting started due to space issue
- In-place upgrade timeouts
- AI Center provisioning failure after upgrading to 2023.10 or later
- SQL validation fails during upgrade
- Longhorn REST API endpoint upgrade/reinstall error
- ArgoCD login failed
- Redis probe failure
- RKE2 server fails to start
- Pods stuck in Init:0/X
- Failure to configure email alerts post upgrade
- No healthy upstream issue
- Document Understanding not on the left rail of Automation Suite
- Failed status when creating a data labeling session
- Failed status when trying to deploy an ML skill
- Migration job fails in ArgoCD
- Handwriting recognition with intelligent form extractor not working
- Failed ML skill deployment due to token expiry
- After Disaster Recovery Dapr is not working properly for Process Mining
- Configuring Dapr with Redis in cluster mode
- Exploring Logs
- Exploring summarized telemetry
Last updated Oct 13, 2025
During the automated upgrade from Automation Suite 2021.10, the CNI provider is migrated from Canal to Cilium. This operation requires that all nodes are restarted. On rare occasions, one or more nodes might not be successfully rebooted, causing pods running on those nodes to remain unhealthy.
                     Identify failed restarts. During the Ansible execution, you might see output similar to the following snippet: TASK [Reboot the servers] *************************************************************************************************************************** fatal: [10.0.1.6]: FAILED! => msg: 'Failed to connect to the host via ssh: ssh: connect to host 10.0.1.6 port 22: Connection timed out'TASK [Reboot the servers] *************************************************************************************************************************** fatal: [10.0.1.6]: FAILED! => msg: 'Failed to connect to the host via ssh: ssh: connect to host 10.0.1.6 port 22: Connection timed out'Alternatively, browse the logs on the Ansible host machine, located at/var/tmp/uipathctl_<version>/_install-uipath.log. If any failed restarts were identified, execute steps 2 through 4 on all nodes.
                     Confirm a reboot is needed on each node. Connect to the each node and run the following command: ssh <username>@<ip-address> iptables-save 2>/dev/null | grep -i cali -cssh <username>@<ip-address> iptables-save 2>/dev/null | grep -i cali -cIf the result is not zero, a reboot is needed.
                     Reboot the node: sudo rebootsudo reboot
- Wait for the node to become responsive (you should be able to SSH to it) and repeat steps 2 through 4 on every other node.
