Last updated Nov 13, 2025
Step 11: Applying miscellaneous settings
Optional: Enabling FIPS 140-2
This section explains how to enable FIPS 140-2 on your machines.
You can enable FIPS on your Red Hat Linux-based virtual machines. To do that, take the following steps:
  1. Enable FIPS by running the following command on all your machines before starting the installation:
    fips-mode-setup --enablefips-mode-setup --enable
  2. Reboot your machines and check if you successfully enabled FIPS by running the following command:
    fips-mode-setup --checkfips-mode-setup --check
Important: Insights is currently not supported on FIPS 140-2-enabled machines. Make sure to disable Insights when installing Automation Suite on a FIPS 140-2-enabled machines.
For details on the additional steps you must take to start using Automation Suite on FIPS 140-2 machines, see Security best practices.
Optional: Configuring the proxy server
To configure a proxy, you need to perform additional configuration steps while setting up your environment with the prerequisites and during the advanced configuration phase of installation time.
The following steps are required when setting up your environment.
Note: We currently do not support HTTPS proxy with self-signed certificates. Make sure you use a public trusted certificate if you are configuring the proxy.
Step 1: Enabling ports on the virtual network
Make sure that you have the following rules enabled on your network security group for the given Virtual Network.
Source
Destination
Route via proxy
Port
Virtual Network
SQL
No
SQL server port
Required for SQL Server.
Virtual Network
Load Balancer
No
9345
6443
Required to add new nodes to the cluster.
Virtual Network
Cluster(subnet)
No
All ports
Required for communication over a private IP range.
Virtual Network
alm.<fqdn>
No
443
Required for login and using ArgoCD client during deployment.
Virtual Network
Proxy Server
Yes
All ports
Required to route traffic to the proxy server.
Virtual Network
NameServer
No
All ports
Most of the cloud services such as Azure and AWS use this to fetch the VM metadata and consider this a private IP.
Virtual Network
MetaDataServer
No
All ports
Most of the cloud services such as Azure and AWS use the IP address 169.254.169.254 to fetch machine metadata.
Step 2: Adding proxy configuration to each node
When configuring the nodes, you need to add the proxy configuration to each node that is part of the cluster. This step is required to route outbound traffic from the node via the proxy server.
  1. Add the following configuration in /etc/environment:
    http_proxy=http://<PROXY-SERVER-IP>:<PROXY-PORT>
    https_proxy=http://<PROXY-SERVER-IP>:<PROXY-PORT>
    no_proxy=alm.<fqdn>,<fixed_rke2_address>,<named server address>,<metadata server address>,<private_subnet_ip>,localhost,<Comma separated list of ips that should not got though proxy server>http_proxy=http://<PROXY-SERVER-IP>:<PROXY-PORT>
  2. Add the following configuration in /etc/wgetrc:
    Mandatory parameters
    http_proxy
    Used to route HTTP outbound requests from the node. This should be the proxy server FQDN and port.
    https_proxy
    Used to route HTTPS outbound requests from the node. This should be the proxy server FQDN and port.
    no_proxy
    Comma-separated list of hosts, IP addresses that you do not want to route via the proxy server. This should be a private subnet, SQL server host, named server address, metadata server address: alm.<fqdn>,<fixed_rke2_address>,<named server address>,<metadata server address>.
    • metadata server address – Most of the cloud services such as Azure and AWS use the IP address 169.254.169.254 to fetch machine metadata.
    • named server address – Most of the cloud services such as Azure and AWS use this to resolve DNS query.
    Important:
    If you use AI Center with an external Orchestrator, you must add the external Orchestrator domain to the no_proxy list.
  3. Verify if the proxy settings are properly configured by running the following command:
    curl -v $HTTP_PROXY
    curl -v <fixed_rke_address>:9345curl -v $HTTP_PROXY
    Important: Once you meet the proxy server requirements, make sure to continue with the proxy configuration during installation. Follow the steps in Optional: Configuring the proxy server to ensure the proxy server is set up properly.
  • Optional: Enabling FIPS 140-2
  • Optional: Configuring the proxy server
  • Step 1: Enabling ports on the virtual network
  • Step 2: Adding proxy configuration to each node
