- Overview
- Requirements
- Deployment templates
- Step 2: Configuring the OCI-compliant registry for offline installations
- Step 3: Configuring the external objectstore
- Step 4: Configuring High Availability Add-on
- Step 5: Configuring SQL databases
- Step 6: Configuring the load balancer
- Step 7: Configuring the DNS
- Step 8: Configuring the disks
- Step 9: Configuring kernel and OS level settings
- Step 10: Configuring the node ports
- Step 11: Applying miscellaneous settings
- Step 13: Generating cluster_config.json
- Certificate configuration
- Database configuration
- Kerberos authentication configuration
- Monitoring configuration
- Cluster administration
- Managing products
- Migrating from in-cluster to external High Availability Add-on
- Migrating from in-cluster registry to an external OCI-compliant registry
- Redirecting traffic for the unsupported services to the primary cluster
- Scaling a single-node (evaluation) deployment to a multi-node (HA) deployment
- Monitoring and alerting
- Migration and upgrade
- Step 8: Deleting the default tenant
- Upgrading Automation Suite
- Executing the upgrade
- Using the Orchestrator Configurator Tool
- Orchestrator appSettings
- Configuring appSettings
- Troubleshooting
- How to clear Redis data
- How to enable Istio logging
- How to upgrade from Automation Suite 2022.10.10 and 2022.4.11 to 2023.10.2
- How to forward application logs to Splunk
- How to clean up unused Docker images from registry pods
- Test Automation SQL connection string is ignored
- Data loss when reinstalling or upgrading Insights following Automation Suite upgrade
- RKE2 not getting started due to space issue
- In-place upgrade timeouts
- AI Center provisioning failure after upgrading to 2023.10 or later
- SQL validation fails during upgrade
- Longhorn REST API endpoint upgrade/reinstall error
- ArgoCD login failed
- Redis probe failure
- RKE2 server fails to start
- Pods stuck in Init:0/X
- Failure to configure email alerts post upgrade
- No healthy upstream issue
- Document Understanding not on the left rail of Automation Suite
- Failed status when creating a data labeling session
- Failed status when trying to deploy an ML skill
- Migration job fails in ArgoCD
- Handwriting recognition with intelligent form extractor not working
- Failed ML skill deployment due to token expiry
- After Disaster Recovery Dapr is not working properly for Process Mining
- Configuring Dapr with Redis in cluster mode
- Exploring Logs
- Exploring summarized telemetry
Last updated Nov 13, 2025
After performing an Automation Suite cluster upgrade, some changes are needed to ensure a new node joins the cluster correctly.
To automate the changes, we recommend using the
upgradeUiPathAS.sh script.
This page provides instructions on how to replace the Custom Script Extension (CSE) on the compute resources so that new nodes can be added to your cluster when upgrading to a new Automation Suite version.
The process described in the following sections downloads the scripts required to perform some minor modifications to the
Azure resources as well as to validate some prerequisites. The scripts are found inside the
<targetVersion> and Modules folders. If the process fails, you are asked whether you want to keep the files.
After ensuring that prerequisites are valid, the
CustomScriptExtension objects are updated on all our compute resources so that newly added nodes use the Automation Suite <targetVersion>. Lastly, the files on the initial cluster nodes are overwritten, to also match the files from the <targetVersion>.
Prerequisites
Make sure you meet the following requirements:
- You must add the Managed Service Identity (MSI) associated with the deployment (named like
<basename>-MSI) as a user assigned identity to all the scalesets/virtual machines in the deployment. To do this, go to Scaleset/virtual machine > Identity > User Assigned > Add. Newer versions of Automation Suite templates might already have this added. - You must grant the existing MSI rights to read/write/manage secrets in the deployed key vault (named like
<basename>-VAULT). To do this, go to the keyvault, select Access Policies, then Add, select all Secret Operations, choose the MSI, then Add. - Make sure to review the
cluster_config.jsonfile and change any boolean values marked as string ("true"/"false") to actual boolean values (true/false). For example:- to enable zone resilience, use
"zone_resilience": true. - to allow the installer to create the databases, use
"sql.create_db": true.
- Ensure your RHEL version for the Virtual Machine Scale Sets (Server, Agent, etc.) is updated and matches the version you are upgrading to.
- If you upgrade from Automation Suite 2022.10 to Automation Suite 2023.4 or later, and Orchestrator is enabled on both the
old and new versions, you must set the
orchestrator.block_classic_executionsflag totruein thecluster_config.jsonfile. Using the flag shows that you agree with blocking classic folders executions. Not using the flag causes the upgrade operation to fail. This parameter is not required in new installations. - If you upgrade to Automation Suite 2023.10 or later, and Insights is enabled on both the old and new environments, you must
set the
insights.external_object_storage.bucket_nameflag to the same bucket used forplatformin thecluster_config.jsonfile. Not using the flag causes the upgrade operation to fail. This parameter is not required in new installations. - If you upgrade to Automation Suite 2023.10 or later, make sure to fill in the following fields in the
cluster_config.jsonifsql.create_dbis set totrue:sql.server_url = "<db_endpoint>" sql.port = "1433" sql.username = <SQL Username> sql.password = <SQL password>sql.server_url = "<db_endpoint>" sql.port = "1433" sql.username = <SQL Username> sql.password = <SQL password> - After the upgrade process, export the new
cluster_config.jsonfile contents to an Azure key vault secret namedclusterConfigin the deployment key vault (for details, see the previous list item). Use the value of theFixedRKEAddressfield as the IP of the Internal Load Balancer. To do this, run a command similar to the following:az keyvault secret set --name clusterConfig --vault-name "<vaultName>" --value "$(cat path/to/cluster_config.json)az keyvault secret set --name clusterConfig --vault-name "<vaultName>" --value "$(cat path/to/cluster_config.json) - On the machine running the upgrade script, you must be logged into Azure and set the context to the correct subscription.
The account must have the
Ownerrole on the resource group where the cluster was deployed. -
If Process Mining is enabled and you want to use the latest version of Airflow, make sure to provide the PostgreSQL connection string for the
AutomationSuite_Airflowdatabase.Refer to SQL requirements for Process Mining for more information.
Note:This is only applicable if you upgrade to Automation Suite 2023.10.9 or higher.
Considerations and recommendations
Before starting the upgrade operation, make sure to take the following recommendations into consideration:
- We strongly recommend updating to the latest RHEL OS version supported by Automation Suite. For details, see Hardware and software requirements.
- Before starting the upgrade operation, you can create two containers named
logsandflagsin the deployment storage account (named<basename>st). If you do not create them, the upgrade script can do that for you. - If the deployed server scalesets do not have a Ceph disk attached, the script creates one and attaches it to the server scaleset.
- The upgrade process changes the VMSS model but does not apply it for older instances.
- When performing an upgrade for a cluster deployed
with Azure templates, an error similar to the one shown in the following image might
occur:
This is due to the way the Azure load balancer works. To fix the issue, modify the
fixed_rke_addressfield in thecluster_config.jsonfile. You must change the value of this field to the IP address of the first server instance prior to running the upgrade command. Thecluster_config.jsonuploaded to the key vault should continue to have the IP address of the ILB since the node is not healthy, and traffic will not be balanced to it.
To successfully perform to upgrade to a new Automation Suite version, take the following steps:
Parameters
You can find descriptions of the parameters needed to update to a specific Automation Suite version in the
cluster_config.json file. You can find the cluster_config.json file at this link.
