- Overview
- Requirements
- Pre-installation
- Preparing the installation
- Granting installation permissions
- Installing the External Secrets Operator
- Running uipathctl
- Migration and upgrade
- Monitoring and alerting
- Cluster administration
- Configuring appSettings
- Configuring NLog
- AI Trust Layer
- Troubleshooting
Last updated Apr 16, 2026
input.json example
The following an example shows an input.json file with all the products enabled, as well as the mandatory and optional configuration parameters for Automation Suite. You can use the example as reference and make changes according to your environment requirements.
Note that the minimum UiPath® product selection requires the platform services to be enabled. Make sure to replace FQDNs, hostnames, usernames and passwords, and SQL connection strings with your own configurations.
"fqdn": "automationsuite.mycompany.com",
"admin_username": "admin",
"admin_password": "****",
"registries": {
"docker": {
"url": "registry.mycompany.com",
"username": "registryuser",
"password": "****",
"pull_secret_value": "****"
"helm": {
"password": "xxxxxx"
"sql_connection_string_template": "Server=tcp:sql.mycompany.com,1433;Initial Catalog=DB_NAME_PLACEHOLDER;Persist Security Info=False;User [email protected];Password='g%3qI2x2_%NPZE3Dvdm9Ng_@J_a%YB_sV_B4NncOHMuM%RTE';MultipleActiveResultSets=False;Encrypt=True;TrustServerCertificate=False;Connection Timeout=30;Max Pool Size=100;",
"sql_connection_string_template_odbc": "SERVER=sql.mycompany.com;DATABASE=DB_NAME_PLACEHOLDER;DRIVER={ODBC Driver 17 for SQL Server};UID=testadmin;PWD={g%3qI2x2_%NPZE3Dvdm9Ng_@J_a%YB_sV_B4NncOHMuM%RTE};;Encrypt=yes;TrustServerCertificate=no;Connection Timeout=30;hostNameInCertificate=sql.mycompany.com",
"sql_connection_string_template_jdbc": "jdbc:sqlserver://sql.mycompany.com;database=DB_NAME_PLACEHOLDER;[email protected];password={UW1zVTc1NkRZYW5IMVFvbFlzdm1rVldrOFA1Y1RRalkK};encrypt=true;trustServerCertificate=false;hostNameInCertificate=*.database.windows.net;loginTimeout=30;",
"sql_connection_string_template_sqlalchemy_pyodbc": "mssql+pyodbc://testadmin%40sql.mycompany.com:<password>@sql.mycompany.com:1433/DB_NAME_PLACEHOLDER?driver=ODBC+Driver+17+for+SQL+Server&TrustServerCertificate=no&Encrypt=yes",
"postgresql_connection_string_template_sqlalchemy_pyodbc": "postgresql+psycopg2://sa:<passowrd>@135.235.240.165:5432/DB_NAME_PLACEHOLDER",
"orchestrator": {
"enabled": true
"profile": "default",
"network": {
"ipv4": { "enabled": true },
"ipv6": { "enabled": true }
"kubernetes_distribution": "openshift",
"ingress": {
"gateway_selector": {
"istio": "ingressgateway"
"ingress_gateway_secret": "istio-ingressgateway-certs",
"namespace": "<istio-system>",
"istio_gateway_service_name": "istio-ingressgateway"
"istioMinProtocolVersion": "TLSV1_3",
"argocd": {
"application_namespace": "uipath",
"project": "uipath"
"storage_class": "managed-premium",
"storage_class_single_replica": "managed-premium",
"storage_class_name_with_rwx_support": "managed-premium",
"exclude_components": [
"argocd",
"monitoring",
"istio",
"logging",
"gatekeeper",
"network-policies",
"velero",
"alerts",
"cert-manager"
"sql": {
"server_url": "sql.mycompany.com",
"port": "1433",
"username": "testadmin",
"password": "****",
"create_db": true
"namespace": "uipath",
"fabric": {
"redis": {
"hostname": "redis.mycompany.com",
"port": 6380,
"password": "xxxxx=",
"tls": true
"external_object_storage": {
"enabled": true,
"storage_type": "s3",
"fqdn": "s3storage.mycompany.com",
"port": 443,
"region": "us-east-2",
"access_key": "***",
"secret_key": "***"
"telemetry_optout": true,
"platform": {
"enabled": true
"automation_hub": {
"enabled": true
"automation_ops": {
"enabled": true
"action_center": {
"enabled": true
"apps": {
"enabled": true
"test_manager": {
"enabled": true
"dataservice": {
"enabled": true
"aicenter": {
"enabled": true
"documentunderstanding": {
"enabled": true
"processmining": {
"enabled": true
"semanticproxy": {
"enabled": true
"insights": {
"enabled": true
"ecs": {
"enabled": true
"llmgateway": {
"enabled": true,
"llmobservability": {
"enabled": true,
"automationsolutions": {
"enabled": true,
"autopiloteveryone": {
"enabled": true,
"maestro": {
"enabled": true,
"taas": {
"enabled": true
"a4d": {
"enabled": true,
"registries": {
"docker": {
"password": "****",
"helm": {
"orchestrator": {
"enabled": true
"network": {
"ingress": {
"argocd": {
"project": "uipath"
"argocd",
"monitoring",
"istio",
"logging",
"gatekeeper",
"network-policies",
"velero",
"alerts",
"cert-manager"
"sql": {
"port": "1433",
"password": "****",
"create_db": true
"fabric": {
"redis": {
"port": 6380,
"tls": true
"enabled": true,
"port": 443,
"secret_key": "***"
"platform": {
"enabled": true
"automation_hub": {
"enabled": true
"automation_ops": {
"enabled": true
"action_center": {
"enabled": true
"apps": {
"enabled": true
"test_manager": {
"enabled": true
"dataservice": {
"enabled": true
"aicenter": {
"enabled": true
"enabled": true
"processmining": {
"enabled": true
"semanticproxy": {
"enabled": true
"insights": {
"enabled": true
"ecs": {
"enabled": true
"llmgateway": {
"enabled": true,
"enabled": true,
"enabled": true,
"enabled": true,
"maestro": {
"enabled": true,
"taas": {
"enabled": true
"a4d": {
"enabled": true,
