Last updated Dec 5, 2025
Configuring appSettings
The Orchestrator configuration consists of an array of Kubernetes config maps and secrets that are loaded in a specific order, and placed in the appSettings section of config maps.
The latest configuration is loaded from the orchestrator-customconfig config map. Any newly loaded configuration overwrites all existing settings that have the same key.
To display the current custom Orchestrator configuration, use the config orchestrator get-config uipathctl command:
uipathctl config orchestrator get-config --app-settings
  "key":"value"
}uipathctl config orchestrator get-config --app-settings
  "key":"value"
The uipathctl commands needed for configuring appSettings are:
  • uipathctl config orchestrator get-config --app-settings- This exports the current configuration in a key-value pair json file, ready for editing.
    You can read more about it here.
  • uipathctl config orchestrator update-config --app-settings appsettings.json- This updates the configuration with your changes.
  1. Export the current custom appSettings configuration to a json file using this command:
    uipathctl config orchestrator get-config --app-settings > appsettings.jsonuipathctl config orchestrator get-config --app-settings > appsettings.json
  2. Edit the exported appsettings.json file as needed. You can add, remove, or change any of its settings.
    Example:
        "Triggers.DisableWhenFailedCount": "20",
        "Triggers.JobsCountStrategy": "NoLimit"
    Note: You must export the file again every time you need to make a change, since the update overwrites all settings.
  3. Update the appSettings configuration using this command:
    orchestrator config updateduipathctl config orchestrator update-config --app-settings appsettings.json
