- Overview
- Requirements
- Pre-installation
- Preparing the installation
- Granting installation permissions
- Installing the External Secrets Operator
- Running uipathctl
- Migration and upgrade
- Monitoring and alerting
- Cluster administration
- Performing database maintenance
- Setting up Kerberos authentication
- Configuring the FQDN post-installation
- Guidelines on upgrading an Active/Passive deployment
- Guidelines on backing up and restoring an Active/Passive deployment
- Configuring appSettings
- Configuring NLog
- AI Trust Layer
- Troubleshooting
You can convert an existing installation into multi-site by taking the following steps:
- Convert the standalone Automation Suite cluster into the primary cluster. For details, see Converting a standalone cluster into a primary cluster.
- Install secondary Automation Suite cluster. For details, see Disaster Recovery - Installing the secondary cluster.
Ensure that the certificates are the same on the primary and secondary clusters. This check is not performed or enforced automatically.
To convert an existing Automation Suite cluster into a primary cluster of the multi-site deployment, take the following steps:
Update
input.json. Add or updatefqdn,cluster_fqdn, and enablemultisite."fqdn" : "<global traffic manager fqdn>" "cluster_fqdn": "<fqdn of the primary cluster>", "multisite": { "enabled": true, "primary": true }"fqdn" : "<global traffic manager fqdn>" "cluster_fqdn": "<fqdn of the primary cluster>", "multisite": { "enabled": true, "primary": true }For details, see the following documentation: Advanced installation experience.
Update the TLS certificate section to configure the new certificate, ensuring it meets the requirements outlined in the section.
Note:It is recommended to keep the FQDN of your existing Automation Suite setup to avoid reconfiguring all your robots.
Reapply the manifest by running the following command:
uipathctl manifest apply input.json --versions versions.jsonuipathctl manifest apply input.json --versions versions.jsonRefer to Installing Automation Suite.
If Istio is managed externally (not by
uipathctl), update the following parameters in the WASM plugin configuration:fqdn- Change the value from thecluster_fqdnto the traffic manager FQDN.uipath_service_namespace- Set this to the same value as thenamespacefield ininput.json.If these parameters are not updated, Orchestrator may display errors such as:URL is invalidRouting error occurs in the WASM plugin: error status returned by host: bad argument
