- Overview
- Requirements
- Pre-installation
- Preparing the installation
- Granting installation permissions
- Installing the External Secrets Operator
- Running uipathctl
- Migration and upgrade
- Monitoring and alerting
- Cluster administration
- Troubleshooting
- 500 errors and rate limiting on S3 requests in ODF
- External Secrets troubleshooting
This section provides troubleshooting steps for resolving issues related to the External Secrets Operator and secretstore configuration in Automation Suite.
To identify and resolve synchronization or authentication issues between your cluster and the external secret provider, follow the steps described in this section.
Begin by checking that the External Secrets Operator pods are running correctly.
If the pods are not in a Running state or show repeated restarts, review their logs for any errors related to authentication, permissions, or misconfiguration.
To check the status of the External Secrets pods and view their logs, run:
kubectl get pods -A | grep external-secrets
kubectl logs -f <pod-name> -n <namespace>kubectl get pods -A | grep external-secrets
kubectl logs -f external-secrets-7d8c9b5f9f-abc12 -n external-secretskubectl logs -f external-secrets-7d8c9b5f9f-abc12 -n external-secrets
If the pods are running correctly, verify that the SecretStore and ExternalSecret resources are properly configured and synchronized.
These resources define how external secrets are retrieved and stored, so any misconfiguration can prevent successful synchronization.
Check ExternalSecret resources
Start by reviewing the ExternalSecret objects in your cluster. This helps confirm that the resources are correctly linked to their SecretStore and that the sync status is valid.
To display and inspect your ExternalSecret resources, run the following commands:
kubectl get externalsecrets -A kubectl describe externalsecret <externalsecret-name> -n <namespace>kubectl get externalsecrets -A kubectl describe externalsecret <externalsecret-name> -n <namespace> - For example, to review a specific ExternalSecret in the
uipathnamespace:kubectl describe externalsecret azure-secret-store -n uipathkubectl describe externalsecret azure-secret-store -n uipath
Check SecretStore resources
Inspect the associated SecretStore configuration. This resource defines the connection details for your secret provider (such as Azure Key Vault), and errors here can block secret synchronization.
- To review the SecretStore definitions, use the following commands:
kubectl get secretstores -A kubectl describe secretstore <secretstore-name> -n <namespace>kubectl get secretstores -A kubectl describe secretstore <secretstore-name> -n <namespace> - For example, to examine a SecretStore configuration in the
uipathnamespace:kubectl describe secretstore azure-secretstore -n uipathkubectl describe secretstore azure-secretstore -n uipath
Check events related to External Secrets
Review any Kubernetes events related to the External Secrets Operator. These events can reveal synchronization failures, permission issues, or provider misconfigurations.
- To view related events, run the following command:When reviewing the event output, look for:
kubectl get events -A | grep external-secretskubectl get events -A | grep external-secrets- Error messages in the Status section
- Conditions indicating whether
Ready: True - Warnings or synchronization failures in the Events section
If you are using Azure Key Vault as your secret provider, ensure that the credentials and configuration are valid and up to date.
Incorrect credentials or missing permissions are common causes of synchronization failures.
- Authentication credentials
- Confirm that the
clientId,clientSecret, andtenantIdvalues are correct. - Ensure the service principal has the required permissions for the Key Vault.
- Confirm that the
- Key Vault access policies
- Verify
GetandListpermissions for secrets. - Ensure the Key Vault firewall settings allow access from your cluster.
- Verify
- Workload identity configuration (if applicable)
- Check that federated credentials are correctly configured.
- Ensure the associated service account has the necessary annotations.
- Key Vault URI
Verify that the
vaultUrlin your SecretStore configuration is correct.Example format:
https://<key-vault-name>.vault.azure.net/https://<key-vault-name>.vault.azure.net/
If your deployment uses a service principal, confirm that it has access to retrieve secrets from Azure Key Vault.
To list the secrets accessible to your service principal, run:
az keyvault secret list --vault-name <key-vault-name>az keyvault secret list --vault-name <key-vault-name>
Review the following common issues and corresponding error messages to help diagnose the problem.
| Issue | Possible cause | Example / error output |
| Secret not found in cluster | Missing Kubernetes secret | Warning InvalidProviderConfig 3s (x4 over 8s) secret-store cannot get Kubernetes secret "azure-service-principal-secret" from
namespace "uipath": secrets "azure-service-principal-secret" not found |
| Invalid credentials | Incorrect client ID, client secret, or tenant ID | error processing spec.data[0] (key: external-object-storage-account-key-10176524), err: azure.BearerAuthorizer#WithAuthorization:
Failed to refresh the Token for request ... StatusCode=400 |
| Missing Key Vault object | Key not present in Azure Key Vault | external-secrets error processing spec.data[0] (key: external-object-storage-account-key), err: Secret does not exist |
kubectl describe externalsecret <name> -n <namespace>
kubectl describe secretstore <name> -n <namespace>kubectl describe externalsecret <name> -n <namespace>
