Automation Hub User Guide
Last updated Jun 26, 2025
Publishing a Live - In Production Automation Idea
Publishing Automation Idea in Live Status to Automation Store
Any Idea from Automation Hub that has the status “Live - In Production” can be published to the Automation Store.
You need to start by identifying the Idea in the Explore Automation Program.
Once you open the Automation Profile, you will see the Publish button available.
docs image
Before you publish
If the source of the idea is not Citizen Development driven, you will need to add the following information related to post-automation data.
The information is optional and if filled, it will show up in the Automation Store profile.
docs image
In the slide out, you will find all the nugpkgs attached to the Automation. You have the option to select from an existing nugpkg or add a new one.
docs image
The Add new option will allow you to attach a new nugpkg to the Automation.
Only nugpkg can be attached using the Upload option.
Publish to the Store
By clicking the Publish button, you will publish the Automation to the Store. This means that the selected nugpkg will be associated with the Automation and this will be important for the consumption part, when the user will want to GET the Automation.
The automation will now be available in the Automation Store for large consumption.
  • Publishing a Live - In Production Automation Idea
  • Publishing Automation Idea in Live Status to Automation Store
  • Before you publish
  • Publish to the Store
