Automation Hub User Guide
Last updated Oct 13, 2025
Automation Hub is enhanced with a new experience that allows business users to browse and search for their ready-to-go automation that can already be consumed. The automation will be sent from Automation Hub to the personal workspace in Orchestrator in just a few clicks.
Important: In the current version of Automation Store, we currently support only the connection with the Cloud Orchestrator that sits on the same tenant as Automation Hub within Automation Cloud. This means that the flows presented below will work only if you are using the Cloud version of the Orchestrator.
