Automation Hub User Guide
Last updated Oct 13, 2025
Column Information
Please find below a list containing all the columns available in the table views from the Automation Pipeline module.
The order of columns is alphabetical, except for the first eight default columns.
Column Title
Source
Automation Name
Displays the name defined by the user in the Submit an idea.
Under the name, is displayed the date when the last update was performed on the automation.
Under "Last Modified" date, is displayed the date when the automation was submitted.
Idea/Automation Profile page > About section
Last Modified
Displays the date when the last update was performed on the automation, in the mm/dd/yyyy format.
Date Submitted
Displays the date when the automation was submitted in mm/dd/yyyy format.
Automation ID
A unique (alpha)numeric identifier manually assigned to the idea.
Auto-generated ID
A unique ID of the automation idea from the database
Priority
The priority level selected for an idea.
Idea/Automation Profile page page
The automation idea description entered during the submission process.
Categories
The automation categories selected during the submission process.
Tags
Custom tags for ideas or automations.
Submitter's Business Unit
The company division/business unit assigned when adding a user.
User Profile page
Submitter's Department
The company department assigned when adding a user.
User Profile page
RPA Software Vendor
The RPA Software Vendor selected when the Cost Benefit Analysis is performed.
Idea/Automation Profile page > Cost Benefit Analysis
Automation Type
The type of automation (attended/unattended) selected when the Cost Benefit Analysis is performed.
License Type
The license type selected when the Cost Benefit Analysis is performed.
Launch Date
Timestamp when the automation idea was moved to Live Phase and Status changed to In Production. Date can be overridden from the Cost Benefit Analysis page - Actual & New Estimate table.
N/A
Idea Source
Shows the path chosen to share the idea/automation in the platform, displaying all submission paths (Employee-driven, CoE-driven, Citizen Developer, Process Mining, Task Mining, Citizen Developer)
Selected submission type
Development Type
The development source selected for each idea.
Phase
The stage of the idea/automation providing information about its life cycle.
Status
The status associated with the idea/automation phase providing a granular tracking of its life cycle.
Idea Phase Approver
Name of the Idea Approver and date when the idea was reviewed.
N/A
Launch Assessment Approver
Name of the Program Manager and date when the Assessment was launched. (action no longer available)
N/A
Qualification Phase Approver
Name of the Program Manager and date when the idea was reviewed.
N/A
Published to Store
Available only for accounts that have migrated to the setup in Automation Cloud and with Automation Store enabled. It shows if the automation has reached Live - In Production and has been published to the Store.
N/A
Collaborators
The users assigned as collaborators for the idea/automation.
Idea/Automation Profile page > Collaborators
Applications Used
The name of the application, the version, and language is displayed.
Idea/Automation Profile page > About section > any Assessment that contains the application question
Idea Score
Represents an overall score indicating how good of a candidate the idea is for automation. It is computed based on the High-Level assessment answers.
Idea/Automation Profile page > About section > Idea Score chart in Idea phase
Automation Potential
A percentage indicator computed to determine how much of the process can be successfully automated.
Idea/Automation Profile page > About section > Assessment KPIs section
Revised Automation Potential
Reflects revised data from Cost Benefit Analysis page in Volume Split Estimations: Automation Potential value in Final After Automation column.
By default, it's populated with the value computed for the Automation Potential in the Detailed assessment. Users with editing rights can modify it.
Potential Benefit
KPI computed based on the Citizen Developer assessment, for automations shared via Share an Automation form.
Automation Profile page: Potential Benefit (across company)
Revised Benefit per company (hours saved/year)
Value calculated from Total Time to perform the work(AS IS) multiplied by the Revised Automation Potential. Where Total Time to perform the work(AS IS) value is taken from the Detailed Assessment.
Revised Benefit per employee (hours saved/year)
Value calculated by dividing the Revised Benefit per company (hours saved/year) by the Number of Employees. Where Number of employees value is taken from the Detailed Assessment.
Revised Benefit per company (FTEs)
Value calculated from FTEs Required multiplied by the Revised Automation Potential. Where FTEs Required value is taken from the Detailed Assessment.
Revised Benefit per employee (FTEs)
Value calculated from Revised Benefit per company(FTEs) divided by the Number of Employees. Where Number of employees value is taken from the Detailed Assessment.
Number of Robots
The number of robots estimated by the algorithm to be needed for automating the idea.
FTR Overridden
Represents the value overridden by user with editing rights in the Cost Benefit Analysis page for the estimated numbers of robots needed for automating the idea.
Revised Benefit per company (currency/year)
Value calculated from Total Cost(AS IS) multiplied by the Revised Automation Potential. Where Total Cost(AS IS) value is taken from the Detailed Assessment.
Revised Benefit per employee (currency/year)
Value calculated from Revised Benefit per company(currency/year) divided by Number of Employees. Where Number of employees value is taken from the Detailed Assessment.
Revised Ease of Implementation
Reflects the corresponding % as per the selection done in Cost Benefit Analysis:
for Easy → EOI value is 83%
for Medium → EOI value is 50%
for Difficult → EOI value is 18%
Else, if no selection was done, the system displays the EOI % computed by the Detailed Assessment algorithm.
Est. Implementation Costs
The estimation of the implementation costs required for this idea.
Est. Running Costs
The estimation of the costs required for the idea to run for 1 year.
Est. Net Benefit Year 1
Cost per year for the process AS IS (computed in the Detailed assessment) - Cost with humans performing the manual process for the transactions that could not be automated - Implementation people cost - Running costs/year.
Idea/Automation Profile page > Cost Benefit Analysis > Estimated Costs & Benefits chart
Est. Net Benefit Year 2
Cost per year for the process AS IS (computed in the Detailed assessment) - Cost with humans performing the manual process for the transactions that could not be automated - Running costs/year.
The Running cost/year = RPA software costs + Other Software costs + Support team + Infrastructure + Other costs.
PDD Link
Field populated only if a PDD link is embedded for the idea. The documents that have been uploaded are not displayed.
Idea/Automation Profile page > Documentation
Interests
The number of interests received by the automation.
Downloads
Display the number of times the automation has been downloaded from the Automation Store.
Automation Store
Requests
Display the number of times the automation has been requested.
Available only for accounts that have not migrated to the setup in Automation Cloud.
Detailed Assessment Version
Displays the version name of the detailed assessment for each idea
Number of Applications
Displays how many applications have been selected in any assessment for each idea
Number of Automation Store Reviews
Displays the number of reviews added in the Automation Store profile
Automation Store
Number of Collaborators
Displays the number of collaborators added to the idea.
Number of Comments
Displays the number of comments and replies added to the idea.
Number of Components
Display the number of components added to the idea.
Idea/Automation Profile page > Components
Number of Documents
Displays the number of uploaded documents to the idea.
Number of Followers
Displays the number of users who have clicked on the follow option for the idea.
Number of Media Items
Displays the number of media items selected.
Idea/Automation Profile page > About section > Misc assessment
Number of Similar Automations
Displays the number of similar automations selected.
Note: The values for Revised KPIs are populated in the Automation Pipeline only after editing and saving the Cost Benefit Analysis section within the Automation Profile page.
Note:
More columns that are part of the detailed or high level assessment can appear in the Automation Pipeline.
As long as a minimum of one idea is linked to a version of an assessment, then the questions part of that assessment are displayed as pipeline columns, showing the answers collected with that idea.
