- Open API
- Introduction to Automation Hub API
- API References
- Generate your Token from Automation Hub
- Input for Automation Pipeline
- Input for Submission Type
- Input for Phase
- Input for Status
- Input for Phase and Status Update
- Input for Business Unit
- Input for Applications
- Input for Category
- Input for Cost Benefit Analysis
- Input for High Level Assessment
- Input for Detailed Assessment
- Input for Automation Idea Creation Date
- Input for Users
- Input for User Status
- User Status Table
- Input for Collaborators
- Output Dictionary
- Automation Hub Open API Power Query Data Parsing
OUT OF SUPPORT
Automation Hub API Guide
Last updated Nov 11, 2024
The GET Collaborators call allows users to retrieve all the users assigned with a collaborator role within a specific automation idea.
Note:
As an input parameter use the automation ID, in order to identify the Automation Idea for which you want to retrieve the list of collaborators.
Key |
Value |
Use Case |
collaborators |
Automation ID |
GET request parameter |
Example: collaborators=72 where 72 is the automation ID
UI Correspondent: Collaborators.
