Automation Hub API Guide
Last updated Apr 19, 2024
Input for Collaborators
The GET Collaborators call allows users to retrieve all the users assigned with a collaborator role within a specific automation idea.
Note:
As an input parameter use the automation ID, in order to identify the Automation Idea for which you want to retrieve the list of collaborators.
Key
Value
Use Case
collaborators
Automation ID
GET request parameter
Example: collaborators=72 where 72 is the automation ID
UI Correspondent: Collaborators.
  • Input for Collaborators
