- Open API
- Introduction to Automation Hub API
- API References
- Generate your Token from Automation Hub
- Input for Automation Pipeline
- Input for Submission Type
- Input for Phase
- Input for Status
- Input for Phase and Status Update
- Input for Business Unit
- Input for Applications
- Input for Category
- Input for Cost Benefit Analysis
- Input for High Level Assessment
- Input for Detailed Assessment
- Input for Automation Idea Creation Date
- Input for Users
- Input for User Status
- User Status Table
- Input for Collaborators
- Output Dictionary
- Automation Hub Open API Power Query Data Parsing
OUT OF SUPPORT
Automation Hub API Guide
Last updated Nov 11, 2024
Note:
For both Automation Idea Creation Date and Automation Idea Update Date filters the used date format is EPOCH.
To convert your dates in EPOC format you can use this converter.
Key |
Value |
Use Case |
createdStart |
The start date for the search. |
GET filter |
createdEnd |
The end date for the search. |
GET filter |
Examples:
Retrieve all Automation Ideas created after 23/07/2020:
createdStart=1595462400
Retrieve all Automation Ideas created before 23/07/2020:
createdEnd=1595462400
Retrieve all Automation Ideas created between 22/07/2020 and 23/07/2020:
CreatedStart=1595376000&createdEnd=1595462400
