OUT OF SUPPORT
Automation Hub API Guide
Last updated Nov 11, 2024
Permissions Per Endpoint
Admin Console
Note: The Open API permission system works by the same principles of the one included in the Automation Hub interface.When an API token is generated with a user associated to it, then the permissions of that user will be reflected in the API calls he can perform via the Open API.
Action
Permissions
Token Type
GET - /hierarchy
Open endpoint that can be accessed by all users, regardless of their permissions in the interface.
Personal TokenUser Assigned TokenTenant Level Token
GET - /appinventory
GET - /users
All users with the Manage Users permission
POST - /adduser
POST - /edituser
All users with the Manage Users Roles permission
GET - /roles
All users with the Manage Users role
Automation Ideas
Action
Permissions
Token Type
GET - /automations
Is limited based on user's permissions to specific categories. For example: if a user is has a "Standard User" permission that applies to "Legal", GET Automations will display all the automations in "Legal".
POST - /automationidea
All users that are allowed to submit Employee Driven ideas as per the permission in the interface.
Personal TokenUser Assigned Token the call works only if you define a submitter in the Body
POST - /coe-automationidea
All users that are allowed to submit CoE Driven ideas as per the permission in the interface.
POST - /automations/status
All users that are allowed to Edit details of ideas as per the permission in the interface.
GET - /cba
All users that are allowed to View details of the Cost Benefit Analysis as per the permission in the interface.
GET - /collaborators
All users that are allowed to View Idea Collaborators as per the permission in the interface.
Automation Pipeline
Action
Permissions
Token Type
GET - /automationpipeline
All users that are allowed to View the Automation Pipeline as per the permission in the interface.
Connect
Need help? Support
Want to learn? UiPath Academy
Have questions? UiPath Forum
Stay updated
