Process Mining user guide
Last updated May 20, 2026
System requirements
Introduction
Using DataBridgeAgent requires a Process Mining server installation. This page gives an overview of the system requirements for the Process Mining server on which you want to use DataBridgeAgent to load data for Process Mining.
Important:
If you want to install Process Mining or any of its components, you need access to an environment, and you need a Process Mining license. Please consult your Process Mining contact. DataBridgeAgent does not require a separate license.
Server OS
Process Mining is a 64-bit program and requires a 64-bit environment. For production systems the following operating systems are supported:
  • Windows 10
  • Windows Server 2019
  • Windows Server 2016
  • Windows Server 2012 R2
    Note:
    For an installation that is solely used for loading data with DataBridgeAgent to Process Mining, Windows 10 suffices.
Minimum system requirements
The following table describes the minimum system requirements:
ComponentMinimal sizeDescription
CPU1 coreStrong single-core performance is recommended.
Memory32 GB
StoragevariableThe disk needs to be large enough for the operating system, Process Mining, the data, and cache files. DataBridgeAgent uses less than 1GB.
Note:
The requirements only apply to a Process Mining server that is solely used for loading data with DataBridgeAgent to Process Mining Automation Suite. See Hardware and software requirements for a complete overview of the requirements for a Process Mining on-premises installation.
  • Introduction
  • Server OS
  • Minimum system requirements
Connect
Need help? Support
Want to learn? UiPath Academy
Have questions? UiPath Forum
Stay updated
