- Release notes
- Before you begin
- Getting started
- Integrations
- Working with process apps
- Working with dashboards and charts
- Working with process graphs
- Working with Discover process models and Import BPMN models
- Showing or hiding the menu
- Context information
- Export
- Filters
- Sending automation ideas to UiPath® Automation Hub
- Tags
- Due dates
- Compare
- Conformance checking
- Root cause analysis
- Simulating automation potential
- Viewing Process data
- Creating apps
- Loading data
- Customizing process apps
- App templates
- Additional resources
- Out-of-the-box Tags and Due dates
- Editing data transformations in a local environment
- Designing an event log
- DataBridgeAgent
- Setup credentials for the SQL Server database
- Extracting data from an SAP source system
- Extracting data via loading .csv files
- Extracting data via an ODBC connection
- Using a Credential store
- System requirements
- Configuring DataBridgeAgent
- Adding a custom connector to DataBridgeAgent
- Using DataBridgeAgent with SAP Connector for Purchase-to-Pay Discovery Accelerator
- Using DataBridgeAgent with SAP Connector for Order-to-Cash Discovery Accelerator
- Extending the SAP Ariba extraction tool
- Performance characteristics
Process Mining
Last updated Jul 24, 2025
If you want to use data directly from your SAP system in Process Mining Automation Suite you must set up the SAP extraction before you can use DataBridgeAgent. See Set up Native SAP Extraction for a detailed description.
