Process Mining user guide
- Before you begin
- Installing Automation Suite
- Process Mining configuration checklist
- System requirements
- Getting started
- Integrations
- Working with process apps
- Working with dashboards and charts
- Working with process graphs
- Working with Discover process models and Import BPMN models
- Showing or hiding the menu
- Context information
- Export
- Filters
- Sending automation ideas to UiPath® Automation Hub
- Tags
- Due dates
- Compare
- Conformance checking
- Root cause analysis
- Simulating automation potential
- Viewing Process data
- Creating apps
- Loading data
- Customizing process apps
- Publishing Dashboards
- App templates
- Additional resources
- Out-of-the-box Tags and Due dates
- Editing data transformations in a local environment
- Designing an event log
- Extending the SAP Ariba extraction tool
- Performance characteristics
Configuration checklist for verifying that Process Mining is working correctly after installation and enablement on Automation Suite.
Introduction
After installing and enabling Process Mining on your on-premises (Automation Suite) environment, make sure to check the list present in this guide that evaluates if Process Mining is working properly.
Process Mining portal
Managing access
Apps
- App Templates
- Create new app wizard
- Editing app settings
- Cloning an app
- Setting data restrictions for a process app
- Deleting an app
Loading data
Customizing apps
- Introduction to dashboards
- Working with the dashboard editor
- Data manager
- Automation manager
- Process manager
- Data transformations
