- Before you begin
- Managing access
- Getting started
- Integrations
- Working with process apps
- Working with dashboards and charts
- Working with process graphs
- Working with Discover process models and Import BPMN models
- Showing or hiding the menu
- Context information
- Export
- Filters
- Sending automation ideas to UiPath® Automation Hub
- Tags
- Due dates
- Compare
- Conformance checking
- Root cause analysis
- Simulating automation potential
- Viewing Process data
- Creating apps
- Loading data
- Transforming data
- Tips for writing SQL
- Exporting and importing transformations
- Viewing the data run logs
- Merging event logs
- Configuring Tags
- Configuring Due dates
- Configuring fields for Automation potential
- Activity Configuration: Defining activity order
- Making the transformations available in dashboards
- Data models
- Adding and editing processes
- Customizing dashboards
- Publishing Dashboards
- App templates
- Notifications
- Additional resources
SQL Server vs. Snowflake
In a local development environment, transformations are run on SQL Server, while Snowflake is used in Process Mining Automation Cloud. Although most SQL statements will work both on SQL Server and Snowflake, there can be slight differences in syntax, which may lead to different return results.
To write SQL statements that work on both database systems:
- Write field names in double quotes, e.g.
Table."Field". - Prevent using SQL functions that are different in Snowflake and SQL Server, e.g.
string_agg()andlistagg().
The pm_utils package comes with a set of functions that work on both database types, refer to Multiple databases. For example, instead of using string_agg() or listagg(), the pm_utils.string_agg() will result in the same behavior for both databases. If pm_utils does not contain the desired function, then a Jinja statement should be created to make sure the right function is called on each database.
String concatenation
To combine to strings, use the pm_utils.concat() function. This will yield the same results for both SQL Server and Snowflake.
Example: pm_utils.concat("This is a nice string", null) = "This is a nice string" Concatenating strings should not be done with operators like + or ||, as they are different for both databases (Snowflake uses || and SQL Server uses +). Also the standard concat() function has different behavior on both systems:
| SQL Server | Snowflake |
null values will be ignored and treated as an empty string. | null values will cause the entire result to be null. |
Sorting
Sorting is handled differently in Snowflake and SQL server.
Example: ... order by "Attribute_1" desc, "Attribute_2" ...
Null values
null will default be sorted first (ascending) | null will default be sorted last (ascending) |
Handling capital letters
| capitals are sorted as expected (AaBbCc) | first sorts by capitals, then by non-capitals (ABCabc) |
Dashes
Example: -Accountant-
| dashes are ignored in sorting (so '-Accountant-' is treated same as 'Accountant') | dashes will be sorted at the top |
Whitespace handling
When you group by values “A“ and “ A“, this is seen as one value in SQL Server, but as two different values in Snowflake. Therefore trimming is advised if your data may cause this issue.
Case sensitivity
By default, SQL Server is case insensitive whereas Snowflake is case sensitive. This means that Table."Field" = "Some_value" and Table."Field" = "SOME_VALUE" will return the same result set in SQL Server, but potentially two different result sets in Snowflake.
You are advised to change the behavior of your local SQL Server database to match Snowflakes behavior, to prevent any problems. This can be accomplished by setting the database collation to a case sensitive value.
