- Before you begin
- Managing access
- Getting started
- Integrations
- Working with process apps
- Working with dashboards and charts
- Working with process graphs
- Working with Discover process models and Import BPMN models
- Showing or hiding the menu
- Context information
- Export
- Filters
- Sending automation ideas to UiPath® Automation Hub
- Tags
- Due dates
- Compare
- Conformance checking
- Root cause analysis
- Simulating automation potential
- Viewing Process data
- Creating apps
- Loading data
- Transforming data
- Tips for writing SQL
- Exporting and importing transformations
- Viewing the data run logs
- Merging event logs
- Configuring Tags
- Configuring Due dates
- Configuring fields for Automation potential
- Activity Configuration: Defining activity order
- Making the transformations available in dashboards
- Data models
- Adding and editing processes
- Customizing dashboards
- Publishing Dashboards
- App templates
- Notifications
- Additional resources
Message: [WARNING]: Deprecated functionality The "tests" config has been renamed to "data_tests".
Possible cause
With the introduction of unit tests in dbt version 1.8, the tests: key was renamed to data_tests:. For existing process apps, this results in a deprecation warning that is displayed when loading data or opening Data transformations.
[WARNING]: Deprecated functionality The `tests` config has been renamed to `data_tests`. Please see https://docs.getdbt.com/docs/build/data-tests#new-data_tests-syntax for more information.
Solution
For default process apps, you can rename the occurrences of the tests: config to data_tests: in the dbt_project.yml and the sources.yml files to fix this. For customized process apps, this can be present in other .yml files as well.
Check out the official dbt documentation on the New data_tests: syntax for more information.
The following illustration shows an example dbt_project.yml file with tests renamed to data_tests.
Preview does not change after changing the query
It can occur that the Preview does not change after you changed the query and run the file.
Possible cause
The sql file is identical to the one in dbt, as it has not been updated since the last run. If you run the file again, no changes will be detected and therefore the Preview table won't be updated. For example, if you add a WHERE condition and run the file, the Preview will only show the filtered records. However, if you remove this WHERE condition and run the file again, the Preview will still only display the previously filtered records, when it should actually show all records.
Solution
Add, or change, a comment in the SQL file. This will force a dbt run and the Preview will be updated.
Message: The selection criterion does not match any nodes. Nothing to do.
The following warning messages are displayed in the data run log.
When you get the two warning messages The selection criterion "+<file>.state:modified+" does not match any nodes and Nothing to do. Try checking your model configs and model specifications args, it means that no changes were detected compared to the last time the queries were run. The Preview panels are showing the most up-to-date version of the data.
To force a complete re-run of your queries, select Apply to dashboards.
