- Before you begin
- Managing access
- Getting started
- Integrations
- Working with process apps
- Working with dashboards and charts
- Working with process graphs
- Working with Discover process models and Import BPMN models
- Showing or hiding the menu
- Context information
- Export
- Filters
- Sending automation ideas to UiPath® Automation Hub
- Tags
- Due dates
- Compare
- Conformance checking
- Root cause analysis
- Simulating automation potential
- Viewing Process data
- Creating apps
- Loading data
- Transforming data
- Tips for writing SQL
- Exporting and importing transformations
- Viewing the data run logs
- Merging event logs
- Configuring Tags
- Configuring Due dates
- Configuring fields for Automation potential
- Activity Configuration: Defining activity order
- Making the transformations available in dashboards
- Data models
- Adding and editing processes
- Customizing dashboards
- Publishing Dashboards
- App templates
- Notifications
- Additional resources
Process Mining user guide
Last updated May 20, 2026
The Activity_order field is used as a tie breaker when two events are happening on the same timestamp.
Option 1: SQL configuration
The following code shows an example of configuring Activity_order with a SQL CASE statement:
case
when tableA."Activity" = 'ActivityA'
then 1
when tableA."Activity" = 'ActivityB'
then 2
when tableA."Activity" = 'ActivityC'
then 3
when tableA."Activity" = 'ActivityD'
then 4
end as "Activity_order"
case
then 1
then 2
then 3
then 4
Option 2: CSV seeds file
Instead of using a SQL CASE statement, you can define Activity_order using the activity_configuration.csv file .
The following illustration shows an example activity_configuration.csv file:
Recommendations
Most UiPath app templates come with predefined fields for activity configuration, which you can adapt to your specific business requirements. If predefined fields are unavailable or insufficient, you can always create custom fields using either SQL or the activity_configuration.csv seeds file, as outlined.
