Process Mining user guide
Input data
The input data panel shows the input tables that have been loaded into the process app as raw data. Select a table to see the fields and the data contents in the data preview. The data preview enables you to check if the input data looks as expected.
Note:
The preview shows 1000 records of data. If you want to filter for specific data, create a temporary debug query, refer to Data transformations.
Note:
The Preview panel shows the data of the last data run in which this table was recalculated. If you have made recent changes, then start a new data run to view its results, refer to Editing data transformations.
Connect
Need help? Support
Want to learn? UiPath Academy
Have questions? UiPath Forum
Stay updated
