solutions-management
Solutions user guide
  • Introduction
    • Getting started
    • Understanding the solution development lifecycle
    • Solution components - Studio Web and Orchestrator
    • Overview of the Solutions UI
    • Developing automations with and without solutions
    • Solutions feature availability
  • Managing solution projects and packages
  • Managing solution deployments
  • Best practices
UiPath platform components that can be packaged and deployed as a solution, with support differences between the Studio Web and Orchestrator workflows in Automation Cloud.
While both workflows target solution deployment (both through Studio Web and Orchestrator), not all solution components have equal support in Studio Web, while some components are only supported via Orchestrator.
For each major product component, the tables below highlight what components are supported in each workflow:
Note:
Studio Web also supports additional solution resources (such as business rules, dependencies, and task catalogs) that are automatically packaged with automation projects but are not deployed as standalone solution components. For more information on those resources, see Studio Web - Designing solutions.
UiPath platform resources that can be packaged, transported and deployed as a solution​
Component (product)When designing the solution in Studio Web (recommended)When creating the solution package from Orchestrator
Action Center - Task Catalog✅✅
Apps✅✅
Data Service - Folder-level entities & choicesets✅✅
Data Service - Tenant-level entities & choicesets✅ (only as a dependency of an already published VB App that is referenced in the Solution)✅
Integration Service - Connections✅✅
Integration Service - Custom connectors✅ (only as a dependency of a connection that uses a custom connector; you can't add a custom connector directly)✅
Orchestrator - Assets (Test, Bool, Integer, Credential)✅✅
Orchestrator - Processes (RPA, Maestro BPMN, Maestro Case, Maestro Flow, Maestro Automate, App, Agent, Testing, API)✅✅
Orchestrator - MCP Servers✅✅
Orchestrator - Queues✅✅
Orchestrator - Storage buckets (Orchestrator, Azure, Amazon S3)✅✅
Orchestrator - Webhooks❌✅
Orchestrator - Libraries❌✅
Context Grounding (Indexes)✅✅
IXP - Models (Preview)✅✅
The table below also includes a more granular breakdown of what Orchestrator and Integration Service triggers can be used.
Triggers (Product or Type)When designing the solution in Studio Web (recommended)When creating the solution package from Orchestrator
Orchestrator
→ Time✅✅
→ Queue✅✅
→ API❌❌
→ Events✅✅
Integration Service
→ Events❌❌
Note:
Only one trigger per entry point is supported. Orchestrator event triggers are pulled in together with the process you add to the solution. Triggers are not visible in the deployment configuration in Studio Web; they become visible and configurable when deploying from Solutions in Orchestrator.
Connect
Stay updated
