solutions-management
Solutions user guide
  • Introduction
  • Managing solution projects and packages
    • Manage a solution project in Orchestrator
    • Manage a solution package in Orchestrator
    • Navigating the package sidebar
  • Managing solution deployments
  • Best practices
Create and manage solution projects in Orchestrator using the Solutions builder in Automation Cloud.
This task is typically performed by an RPA developer.
You can create a solution via Studio Web or via the Solutions builder in Orchestrator.
Note:
Use the Solutions builder in Orchestrator to assemble a solution project based on already published artifacts. If you are building your solution from scratch, we recommend Studio Web.
Create a solution project​
Create a solution in Studio Web​
To start building a solution in Studio Web, refer to the steps described in Creating solutions and Designing solutions from the Studio Web user guide.
Once your solution is built, you can publish it to the tenant feed, to a folder feed, or to your Personal Workspace. To learn how to publish a solution, refer to Publishing and deploying solutions from the Studio Web guide.
Create a solution in Orchestrator​
  1. Select the Solutions tab at tenant level.
  2. Select the Projects tab then the New project button.
  3. In the Create solution project window, provide a name for the project and, optionally, a description, then select Continue.
    The Solutions builder opens with the message "Start building your solution by adding solution resources from this tenant". The Selected resources picker opens for a new project and shows a folder tree and a search field (Search resources in this tenant by name…).
  4. Select the resources you plan to include in your solution, then select Add. You can only observe the resources you have access to in the source environment. To close the picker without adding resources, select Cancel.
  5. Select the resources included in your solution to view and optionally update their properties in the Resource properties panel. The builder shows the Resources and Resource properties panels. Each resource has a Sync button and a delete icon. There are two types of properties:
    • Read-only properties - Changing these properties may break the solution. The only way to change read-only properties is by going back to your development environment and making the changes. Then, come back to the Solution builder to remove the old component, then reimport it to fetch the latest info.
    • Configurable properties - If you know that different values are required in the target deployment environment, you can configure these properties to ease the deployment experience. You can also change these properties within the deployment wizard if needed. Configurable fields have a lock icon (Lock [field name]) that locks the value.
      Note:
      In cases where property differences across environments exist, and the correct values are uncertain during the solution packaging process, it is recommended to leave these fields blank by removing the default values. This way, it is easier to notice which fields require specific input during the deployment phase.
  6. To generate a solution package, select the Publish button in the upper-right corner of the builder, next to Settings, and provide the following details in the newly open panel:
    • Solution root folder name - Mandatory. The name provided at deployment time for the solution root folder. The administrator can change it when performing a deployment. Pre-filled with the folder of the first resource you added.
    • Package name - Mandatory.
    • Package version - Mandatory.
    • Description - Optional.
  7. Select Publish. A dialog says that packaging has started. Select Go to packages to open the Packages tab, or Continue editing to stay in the builder.
  8. Return to the Solutions view in Orchestrator. You should now observe your newly created packages in the Packages tab.
Note:
You can interact with the aforementioned flow at any time and return to the Projects tab to resume work on your project.
Edit a published solution project​
You can edit a published project so that you can apply any of the following changes:
  • Changes to the solution structure: add or remove solution components.
  • Changes to the component properties.
To edit a published solution project, you can open a solution project in Studio Web, or take the following steps in Orchestrator:
  2. Navigate to the Projects tab and locate the solution project you want to modify. Select the Edit (pencil) icon for the project.
    The Solutions builder opens directly. There is no version to choose.
  3. The Resources and Resource properties panels are now open, allowing you to make the desired changes:
      Note:
      If you make changes to read-only component properties in the source environment, you must use the Sync functionality to fetch the latest data.
      As a general rule, you can update any of the configurations that were also editable at initial deployment time. However, there are some properties that you cannot change if they were configured in a certain way, as is the case of the store in encrypted format for queues.
  4. Once you are done making changes, select Publish. You have now created a new solution package version.
After the first publish, the builder shows Publish history: each version with its date, author, package name, and a download icon. The Settings button opens Project Settings, where you can change the Project name, Solution root folder name, and Description.
  • Create a solution project​
  • Create a solution in Studio Web​
  • Create a solution in Orchestrator​
  • Edit a published solution project​
Connect
Stay updated
