solutions-management
  • Introduction
  • Managing solution projects and packages
    • Creating a solution project
    • Editing a published solution project
    • Transporting a solution package
    • Checking the package status
    • Navigating the package sidebar
  • Managing solution deployments
Solutions user guide
Last updated Mar 24, 2026
You can edit a published project so that you can apply any of the following changes:
  • Changes to the solution structure: add or remove solution components;
  • Changes to the component properties.
To edit a published solution project, you can open a solution project in Studio Web, or take the following steps in Orchestrator:
  1. Select the Solutions tab at tenant level.
  2. Navigate to the Projects tab and locate the solution project you want to modify. Select the three-dot menu, then proceed to edit the targeted version.
    The Solutions builder now opens.
  3. The Solution explorer and Component properties panels are now open, allowing you to make the desired changes:
      Note:
      If you make changes to read-only component properties in the source environment, you must use the Sync functionality to fetch the latest data.
      As a general rule, you can update any of the configurations that were also editable at initial depoyment time. However, there are some properties that you cannot change if they were configured in a certain way, as is the case of the store in encrypted format for queues.
  4. Once you are done making changes, select Publish. You have now created a new solution package version.
Connect
Need help? Support
Want to learn? UiPath Academy
Have questions? UiPath Forum
Stay updated
