Process Mining
Last updated Nov 6, 2025
TemplateOne-MultiFiles Input Fields
Introduction
If your data for cases and events is split up into different input files, you use the TemplateOne-MultiFiles app template.
If you want to create a new TemplateOne process app, you must upload a dataset that contains the data to be used in the TemplateOne.
For each table, this must be a tsv (tab-separated) file or .csv (comma-separated) file that contains a column for each input field.
This section contains an overview of the input tables for TemplateOne-MultiFiles. For each field, the name, the data type, and a short description are displayed. Apart from that, it is indicated whether the field is mandatory.
Important:
Table names and field names are case-sensitive. Always make sure that the field names (column headers) in your dataset match the field names (in English) in the tables below and that the file names match the table names.
Mandatory and optional fields
Your input data file can have different fields or different field names. However, some fields are mandatory, which means that the data must be available in your input data file for a correct working of the process app.
Note: When a field is mandatory, it should not contain NULL values.
Field types
The following table describesthe different field types and their default format settings.
Field type
Format
boolean
true, false, 1, 0
datetime
yyyy-mm-dd hh:mm:ss[.ms], where [.ms] is optional.
Refer to the official Microsoft documentation if you want to change the date format.
double
Decimal separator: . (dot)
Thousand separator: none
text
N/A
integer
Cases_raw
The Cases_raw table contains the detailed information for the status, type, value and description for the related case.
Name
Data type
Mandatory Y/N
Case_ID
text
Y
The unique identifier of the case the event belongs to.
Case
text
N
A user-friendly name to identify the case.
Case_status
text
N
The status of the case in the process. For example, open, closed, pending, approved, etc.
Case_type
text
N
The categorization of the cases.
Case_value
double
N
A monetary value related to the case.
Custom Case Fields
Additionally, custom case fields are available.
  • 30 fields of type text;
  • 10 fields of type double;
  • 10 fields of type datetime;
  • 10 fields of type boolean;
  • 10 fields of type duration.
Custom fields have generic names.The following table describes the custom fields that can be used in a process app.
Name
Data type
Mandatory Y/N
custom_case_text_{1...30}
text
N
custom_case_number_{1...10}
double
N
custom_case_datetime_{1...10}
datetime
N
custom_case_boolean_{1...10}
boolean
N
custom_case_duration_{1...10}
integer
N
Note:
When you use a custom field, you should rename the field in using Data manager to a name that matches the value. Check out Fields.
Custom fields that are empty in your dataset, are not displayed in Process Mining.
Event_log_raw
The Event_log table contains information on the activities executed in the process.
Name
Data type
Mandatory Y/N
Activity
text
Y
The name of the event. This describes the step in the process.
Case_ID
text
Y
Event_end
datetime
Y
The timestamp associated with the end of executing the event.
Event_ID
integer
Y*
The unique identifier of the event.
Automated**
boolean
N
Indicates whether the event is manually executed or automated.
Event_cost
double
N
The costs for executing the event.
Event_detail
text
N
Information related to the event.
Event_start
datetime
N
The timestamp associated with the start of executing the event.
Team
text
N
The team that executed the event.
User
text
N
The user who executed the event.
*) Event_ID is optional, but is mandatory if you want to use Due dates.
**) Automated is part of the input data. However, if you need to derive whether an event is automated or not, you need to customize this in the data transformations to create that logic based on the required information. It is recommended to do this in the Event_log.sql file. Locate the statement that contains ...as "Automated" and replace it, for example, with a statement as displayed below.
case when Event_log_base."User" = 'A' then pm_utils.to_boolean('true') else pm_utils.to_boolean('false') end as "Automated"case when Event_log_base."User" = 'A' then pm_utils.to_boolean('true') else pm_utils.to_boolean('false') end as "Automated"
Custom Event Fields
Additionally, custom event fields are available.
  • 5 fields of type duration.
Custom fields have generic names. The following table describes the custom fields that can be used in a process app.
Name
Data type
Mandatory Y/N
custom_event_text_{1...30}
text
N
custom_event_number_{1...10}
double
N
custom_event_datetime_{1...10}
datetime
N
custom_event_boolean_{1...10}
boolean
N
custom_event_duration_{1...5}
integer
N
Note:
Tags_raw
The Tags_raw table contains fields for tags that are defined in your process. If you upload tags, the Tags dashboard will be enabled.
Note:
Tags_raw is an optional table.
Name
Data type
Mandatory Y/N
Case_ID
text
Y
The unique identifier of the case the tag belongs to.
Tag
text
Y
A user-friendly name to identify the tag.
Tag_type
text
N
The category to which the tag belongs to.
Due_dates_raw
The Due_dates_raw table contains fields for due dates that are defined in your process. If you upload due dates, the Due dates dashboard will be enabled.
Note:
Due_dates_raw is an optional table.
Name
Data type
Mandatory Y/N
Event_ID
integer
Y
The unique identifier of the event the due date belongs to.
Due_date
text
Y
The name of the due date.
Actual_date
datetime
Y
The actual moment the event associated with the due date happened.
Expected_date
datetime
Y
The moment the event associated with the due date was expected to happen.
  • Introduction
  • Mandatory and optional fields
  • Field types
  • Cases_raw
  • Custom Case Fields
  • Event_log_raw
  • Custom Event Fields
  • Tags_raw
  • Due_dates_raw
Connect
Need help? Support
Want to learn? UiPath Academy
Have questions? UiPath Forum
Stay updated
