Process Mining
Last updated Apr 15, 2025
Configuring CData Sync for TemplateOne
Introduction
Next to the Upload data option to load data for a TemplateOne process app, you can also use CData Sync to load data from files. This page describes how to use CData Sync to set up a source connection to load data from files into a Process Mining TemplateOne process app.
In general, when you want to use CData Sync to load data from files, you should follow the steps as described in Loading data using CData Sync to set up data loading using CData Sync.
Since specific settings are required when loading data from files into TemplateOne, pay attention to the steps described below.
TemplateOne Specific Steps When Configuring CData Sync
Setting up the Source Connection
Select CSV as the source system to which you want to create a connection from the list, and make sure to define the settings as described in Create a source connection.
Table Replication
Once the job is correctly setup, create a Custom Query paste the following queries (each query needs to maintain the semicolon at the end). Make sure you save all changes. See Create a job.
For TemplateOne-SingleFile use the following query:
REPLICATE [Event_log_raw] SELECT * FROM [Event_log]REPLICATE [Event_log_raw] SELECT * FROM [Event_log]
For TemplateOne-MultiFiles use the following query:
REPLICATE [Event_log_raw] SELECT * FROM [Event_log];
REPLICATE [Cases_raw] SELECT * FROM [Cases];
REPLICATE [Tags_raw] SELECT * FROM [Tags]REPLICATE [Event_log_raw] SELECT * FROM [Event_log];
  • Introduction
  • TemplateOne Specific Steps When Configuring CData Sync
  • Setting up the Source Connection
  • Table Replication
