- Release notes
- Before you begin
- Getting started
- Managing access
- Working with process apps
- Creating process apps
- Loading data
- Customizing process apps
- Data transformations
- TemplateOne app template
- Purchase to Pay app template
- Order to Cash app template
- Basic troubleshooting guide
Process Mining
Configuring CData Sync for TemplateOne
linkIntroduction
linkNext to the Upload data option to load data for a TemplateOne process app, you can also use CData Sync to load data from files. This page describes how to use CData Sync to set up a source connection to load data from files into a Process Mining TemplateOne process app.
In general, when you want to use CData Sync to load data from files, you should follow the steps as described in Loading data using CData Sync to set up data loading using CData Sync.
Since specific settings are required when loading data from files into TemplateOne, pay attention to the steps described below.
TemplateOne specific steps when configuring CData Sync
linkStep 2: Setting up the source connection
Select CSV as the source system to which you want to create a connection from the list, and make sure to define the settings as described in Loading data using CData Sync.
Step 4: Creating the extraction job - step 7
On the Tables tab add a custom query that mirrors the output of the connector you are using.
For TemplateOne-SingleFile use the following query:
REPLICATE [Event_log_raw] SELECT * FROM [Event_log]
For TemplateOne-MultiFiles use the following query:
REPLICATE [Event_log_raw] SELECT * FROM [Event_log];
REPLICATE [Cases_raw] SELECT * FROM [Cases];
REPLICATE [Tags_raw] SELECT * FROM [Tags]
