Process Mining
Last updated Feb 26, 2025
TemplateOne-MultiFiles input fields
Introduction
If your data for cases and events is split up into different input files, you use the TemplateOne-MultiFiles app template.
If you want to create a new TemplateOne process app, you must upload a dataset that contains the data to be used in the TemplateOne.
For each table, this must be a tsv (tab-separated) file or .csv (comma-separated) file that contains a column for each input field.
This section contains an overview of the input tables for TemplateOne-MultiFiles. For each field, the name, the data type, and a short description are displayed. Apart from that, it is indicated whether the field is mandatory.
Important: Table names and field names are case-sensitive. Always make sure that the field names (column headers) in your dataset match the field names in the table below and that the file names match the table names.
If you are extracting the data using CData Sync, `_raw` has to be added to the table names listed below, e.g. `Event_log_raw`.
Mandatory and optional fields
Your input data file can have different fields or different field names. However, there are some fields mandatory for TemplateOne, which means that the data must be available in your input data file for a correct working of TemplateOne.
Note: When a field is mandatory, it should not contain NULL values.
Below is an overview of the input tables for TemplateOne-MultiFiles.
Field types
Below is an overview of the different field types and their default format settings.
Field type
Format
boolean
true, false, 1, 0
datetime
yyyy-mm-dd hh:mm:ss[.ms], where [.ms] is optional.
double
Decimal separator: . (dot)
Thousand separator: none
text
N/A
integer
Cases
The Cases table contains the detailed information for the status, type, value and description for the related case.
Name
Data type
Mandatory Y/N
case_id
text
Y
The unique identifier of the case the event belongs to.
case
text
N
A user-friendly name to identify the case.
case_status
text
N
The status of the case in the process. For example, open, closed, pending, approved, etc.
case_type
text
N
The categorization of the cases.
case_value
double
N
A monetary value related to the case.
Custom Case fields
Additionally, custom case fields are available for TemplateOne.
  • 30 fields of type text;
  • 10 fields of type double;
  • 10 fields of type datetime;
  • 10 fields of type boolean;
  • 10 fields of type duration.
Custom fields have generic names. Below is an overview of the custom fields that can be used in a process app.
Name
Data type
Mandatory Y/N
custom_case_text_{1...30}
text
N
custom_case_number_{1...10}
double
N
custom_case_datetime_{1...10}
datetime
N
custom_case_boolean_{1...10}
boolean
N
custom_case_duration_{1...10}
integer
N
When you use a custom field, you should rename the field in using Data manager to a name that matches the value. See Fields.
Custom fields that are empty in your dataset, are not displayed in Process Mining.
Event_log
The Event_log table contains information on the activities executed in the process.
Name
Data type
Mandatory Y/N
activity
text
Y
The name of the event. This describes the step in the process.
case_id
text
Y
event_end
datetime
Y
The timestamp associated with the end of executing the event.
automated
boolean
N
Indicates whether the event is manually executed or automated.
event_cost
double
N
The costs for executing the event.
event_detail
text
N
Information related to the event.
event_start
datetime
N
The timestamp associated with the start of executing the event.
team
text
N
The team that executed the event.
user
text
N
The user who executed the event.
Custom Event fields
Additionally, custom event fields are available for TemplateOne.
  • 10 fields of type datetime.
  • 5 fields of type duration.
Name
Data type
Mandatory Y/N
custom_event_text_{1...30}
text
N
custom_event_number_{1...10}
double
N
custom_event_datetime_{1...10}
datetime
N
custom_event_boolean_{1...10}
boolean
N
integer
N
Tags
The Tags table contains fields for tags that are defined in your process. If you upload tags in TemplateOne-MultiFiles, the Tags dashboard will be enabled.
Name
Data type
Mandatory Y/N
case_id
text
Y
The unique identifier of the case the tag belongs to.
tag
text
Y
A user-friendly name to identify the tag.
tag_type
text
N
The category to which the tag belongs to.
  • Introduction
  • Mandatory and optional fields
  • Field types
  • Cases
  • Custom Case fields
  • Event_log
  • Custom Event fields
  • Tags
