Process Mining
Loading data using CData Sync
Important:
There can be issues with loading data using an Azure Blob destination connection for existing process apps when using CData Sync versions 2025 - 25.1.x. We strongly recommend using CData Sync 2024 - 24.1.x versions instead and advise against upgrading to CData Sync 2025 - 25.1.x versions.
Note:
The information in this page is based on CData Sync 2024 - 24.1.8885. If you use an other version of CData Sync, field names or functions may be different.
CData Sync is a tool that is used to extract data from source systems into Process Mining. The supported source systems can be found on the Sources page on the CData Sync website. Refer to the official CData Sync website for more information on CData Sync.
This page describes how to use CData Sync to load data from your source system into a process app in Process Mining.
Prerequisites​
It is assumed that you have:
Steps​
Setting up data load using CData Sync requires several steps to be performed.
  1. Install CData Sync
  2. Create a source connection
  3. Create a destination connection
  4. Create a job
  5. Run the job
  • Prerequisites​
  • Steps​
Connect
Stay updated
