studio
- Release Notes
- Getting Started
- Setup and Configuration
- Automation Projects
- Dependencies
- Types of Workflows
- File Comparison
- Automation Best Practices
- Source Control Integration
- Debugging
- The Diagnostic Tool
- Workflow Analyzer
- About Workflow Analyzer
- ST-DBP-023 - Empty Workflow
- ST-USG-032 - Required Tags
- Variables
- Arguments
- Imported Namespaces
- Coded automations
- Control Flow
- Object Repository
- Logging
- Studio testing
- Extensions
- About extensions
- SetupExtensions tool
- Hardware and software requirements
- Installing the UiPath Remote Runtime
- Remote Runtime architecture
- Screen resolution settings
- Group Policies
- Multiple browser profiles
- Group Policy conflict
- Install from Group Policy
- Uninstalling
- Group Policies
- List of extensions for Edge
- SAP Solution Manager plugin
- Excel Add-in
- Troubleshooting
Studio User Guide
Last updated Oct 20, 2025
The
ChromeNativeMessaging.exe
enables communication between the UiPath Extension for Edge and the UiPath Studio/Robot.
- Open Microsoft Edge.
- Open Task Manager.
- Check if the
process is running. -
If the process is not running:
