- Release notes
- Getting started
- Configuration
- Integrations
- Authentication
- Working with Apps and Discovery Accelerators
- Working with charts
- Working with Process graphs
- Sending automation ideas to UiPath Automation Hub
- Filters
- Favorites
- Export
- Selecting the preferred language
- AppOne menus and dashboards
- AppOne setup
- TemplateOne 1.0.0 menus and dashboards
- TemplateOne 1.0.0 setup
- TemplateOne menus and dashboards
- TemplateOne 2021.4.0 setup
- Purchase to Pay Discovery Accelerator menus and dashboards
- Purchase to Pay Discovery Accelerator Setup
- Order to Cash Discovery Accelerator menus and dashboards
- Order to Cash Discovery Accelerator Setup
- Basic Connector for AppOne
- SAP Connectors
- Introduction to SAP Connector
- SAP input
- Checking the data in the SAP Connector
- Adding process specific tags to the SAP Connector for AppOne
- Adding process specific Due dates to the SAP Connector for AppOne
- Adding automation estimates to the SAP Connector for AppOne
- Adding attributes to the SAP Connector for AppOne
- Adding activities to the SAP Connector for AppOne
- Adding entities to the SAP Connector for AppOne
- SAP Order to Cash Connector for AppOne
- SAP Purchase to Pay Connector for AppOne
- SAP Connector for Purchase to Pay Discovery Accelerator
- SAP Connector for Order-to-Cash Discovery Accelerator
- Superadmin
- Dashboards and charts
- Tables and table items
- Application integrity
- How to ....
- Working with SQL connectors
- Introduction to SQL connectors
- Setting up a SQL connector
- CData Sync extractions
- Running a SQL connector
- Editing transformations
- Releasing a SQL Connector
- Scheduling data extraction
- Using SQL connectors for released apps
- Generating a cache with scripts
- Separate development and production environments
- Useful resources
Process Mining
linkIntroduction
linkDifferent UiPath products work together to discover, investigate and build automation and communicate process improvements. UiPath Automation Hub is used to turn ideas for automation that are discovered from UiPath Process Mining into real automated implementations. If UiPath Process Mining is set up for integration with UiPath Automation Hub you can send ideas for process improvements that are subject for automation directly from the Process Graph to UiPath Automation Hub.
In UiPath Automation Hub the idea will be investigated and processed. Once the automation is built, the impact should become visible in UiPath Process Mining.
Submitting automation ideas
linkWhen you identify a bottleneck in your process while monitoring, for example when a manual activity takes a long time to be executed, you might want to send a request to automate the activity to UiPath Automation Hub. You can do this directly from the Process Graph.
Follow these steps to submit a request for automation and send it to UiPath Automation Hub.
Step |
Action |
1 |
In the Process Graph, right click on the activity that you identify as a possible candidate for automation. |
2 |
Select Submit as automation idea... from the context menu. The Submit As Automation Idea dialog is displayed. See illustration below. |
3 |
Enter the required details for the automation request. See below for a description of the fields. |
4 |
Click on SEND. |
You can also select an activity and click on the icon at the top of the Process Graph to open the Submit As Automation Idea dialog.
If you have a process graph filter active, for example Select cases that pass through this activity, the activity is automatically selected as the activity for the automation idea when you click on the
Send to Automation Hub icon. See also Process graph filters.
Send to Automation Hub dialog
linkThe Send to Automation Hub dialog enables you to provide input for the Detailed Assessment of the automation idea to be sent to UiPath Automation Hub. Some of the fields already have a prefilled value, but you can change them according to your needs.
The fields listed below are in the UiPath Automation Hub default assessment questions. In the Automation Hub Detailed Assessment the default questions are customizable and if these questions are modified, you will see different fields in the Send to Automation Hub dialog. Please note that in this case the automation idea may not be sent properly and error messages may be displayed.
Refer to the Automation Hub documentation for more information.
Below is a description of the fields of the Send to Automation Hub dialog.
Element |
Description |
Automation idea title |
Enter a title for the automation idea. You can, for example, use the format
Activity name - Process name .
Note: the title must be a unique title within the UiPath Automation Hub instance.
Activity |
The activity that is indicated as a candidate for automation. Note: If you used the Submit an automation context menu item from a specific activity or created the idea from a selected activity, this activity is selected by default.
Business area |
The name of a category that is predefined in UiPath Automation Hub as an area for automation to which the automation idea is mapped. |
Percentage of digital input |
Enter a number that indicates the percentage of digital input. |
Percentage of structured digital input |
A drop-down list containing options to select how much of the digital input is structured. |
Number of ways to complete the activity |
A drop-down list containing options to indicate the number of ways to complete the activity that is extracted from the data. |
Description |
A short description of the automation idea where you can include any pre-conditions, inputs or triggers, and outcomes. |
Automation submitted
linkWhen the idea for automation was successfully sent a confirmation dialog is displayed. See illustration below.
When you click on the hyperlink in the confirmation dialog, you are redirected to the idea in UiPath Automation Hub where you are assigned as the submitter of the idea.
In Automation Hub the Process Mining Dashboard link is available to go back to the process graph from which the idea was submitted. See illustration below.
Moreover, the process graph from which the idea was submitted is displayed in the Media section at the bottom of the page. :-1:
The Benefit Per Employee (currency/year) displayed in the Assessment KPIs pane in Automation Hub is calculated from the sum of the annual event costs.
There might be a slight deviation between the Number of events displayed in Process Mining and the Volumes (per Frequency) in Automation Hub. It always extrapolates to a full year.
