- Automation Suite on Linux Release Notes
- Automation Suite on EKS/AKS Release Notes
Automation Suite release notes
Release date: October 17, 2024
Erratum - added January 27, 2025: Automation Suite on EKS now supports Amazon Linux 2023 (AL2023).
We are excited to announce that you can now update the Fully Qualified Domain Name (FQDN) of your Automation Suite cluster.
For details about the FQDN update procedure, see Configuring the FQDN post-installation.
We made the following improvements to the migration workflows:
When moving the Identity data of your tenants from standalone Orchestrator to Automation Suite, the tenant name in Automation Suite is now the same as the original tenant name in standalone Orchestrator. Previously, the Automation Suite tenant name was automatically generated in the
tenant_xxxxxxxxformat, wherexxxxxxxxsignified the first eight characters of the Automation Suite organization ID. For more information, see Step 1: Moving the Identity organization data from standalone to Automation Suite -
We updated our documentation of the migration steps to clarify that you have the option to migrate multiple standalone product tenants to either a single Automation Suite organization or multiple Automation Suite organizations. For more information, see Step 1: Moving the Identity organization data from standalone to Automation Suite and Step 4: Merging organizations in Automation Suite.
We updated our documentation of the post-migration steps to clarify that you can clean up the old Redis keys for both Orchestrator and Identity from the cloud-based Redis console. For more information, see Removing old cache keys.
- Running a health check on AKS led to
an
[ARGOCD_REDIS_PODS]failure for ArgoCD Redis HA, although ArgoCD Redis HA is no longer used in Automation Suite on AKS. The behavior no longer occurs. -
In a proxy environment, if the proxy server used the same port as the TCP port of any other service in the Istio service mesh, such as port 8080, pods could not communicate with the FQDN, and an error message was displayed. The behavior no longer occurs.Note: If you previously created a service entry according to the workaround in Pods cannot communicate with FQDN in a proxy environment, we recommend that you delete the service entry after you upgrade to Automation Suite 2023.10.6 or later. To delete the service entry, use the following command:
kubectl delete serviceentry proxy -n uipathkubectl delete serviceentry proxy -n uipath
Log streaming does not work in proxy setups
Erratum - added June 26, 2025: Log forwarding does not work in proxy setups because the proxy environment variables were not set in the logging pods. To address the issue, refer to the Troubleshooting section.
We fixed the issue in Automation Suite 2023.10.10.
Licensing SQL connection error
Erratum - added June 26, 2025: Licensing SQL connection errors occur when the Data Source property specified both a named instance and a port.
Insights dashboards excluded from backups
Erratum - added April 2, 2025: An issue is preventing the inclusion of Insights dashboards in backups. To address this issue, refer to the Backing up the cluster page. The issue is fixed in Automation Suite 2023.10.8.
Fluentd logs transmission failure
Erratum - added February 13, 2025: An issue prevents Fluentd from sending logs to remote locations due to a lack of memory buffer. To address this issue, you must add a memory limit for Fluentd to prevent disruptions or delays when transmitting logs to a remote location.
This issue is fixed in Automation Suite 2023.10.8.
Microsoft Entra ID limitations
Erratum - added January 20, 2025: Insights and Task Mining do not currently support Microsoft Entra ID (formerly Azure Active Directory) authentication configuration for access to SQL, storage, and other resources that support Microsoft Entra.
Cannot migrate between Automation Suite flavors when Apps is enabled
business-apps/ba-migration-k8-utils image.
business-apps/ba-migration-k8-utils image in the versions.json file from 2023.10.4 to 2023.10.6 before running the migration command.
We fixed the issue in Automation Suite 2023.10.7.
Insights volumes created in two different zones following migration
Erratum - added December 18, 2024: When you migrate from Automation Suite on Linux to Automation Suite on EKS/AKS, Insights-related volumes are occasionally created in two different zones. As a result, you may encounter issues when bringing up the Insights service. To address the problem, see Troubleshooting.
Failing EKS backup related to Velero version
Erratum - added December 18, 2024: A Velero version-related issue causes the Automation Suite on EKS backup to fail. To address the issue, you must manually modify the Velero deployment. For details, see the Troubleshooting section.
Upgrade failure due to overridden Insights PVC sizes
Erratum - added December 18, 2024: An issue causes upgrades to fail when the existing Insights PVC sizes are inadvertently overridden. To address this problem, you must manually change the PVC sizes in ArgoCD UI. For details, see the Troubleshooting section.
This issue is fixed in Automation Suite 2023.10.7.
Insights dashboards backup issue
Erratum - added December 18, 2024 We have identified an issue with the backup logic in Automation Suite for AKS/EKS. Specifically, this defect excludes the backup of Insights dashboards. However, all historical data is successfully backed up.
We are working diligently to resolve this issue. We aim to develop and implement a mitigation approach as early as possible.
If you are using Automation Suite on AKS/EKS along with UiPath Insights, this defect may affect your operations. While we address this issue, we suggest manually exporting your dashboards as a preventive measure.
Note that backups are mainly used as a recovery method in the event of a disaster-level incident or in preparation for an Automation Suite upgrade. This is particularly useful if an upgrade fails and stored data needs to be restored to its previous state.
Test Automation SQL connection string is ignored
orchestrator.testautomation section of the
input.json file, the uipathctl binary ignores the
connection string and uses the one under the orchestrator section
instead. To address the problem, see the Troubleshooting section.
We recommend that you regularly check the deprecation timeline for any updates regarding features that will be deprecated and removed.
Product versions
To find out what has changed on each Automation Suite product, visit the following links.
If the product is greyed out, this new Automation Suite version does not bring any changes to it.
| DISCOVER | BUILD | MANAGE | ENGAGE |
Automation Ops 2023.10.5 | AI Center 2023.10.6 | Action Center 2023.10.6 | |
| Task Mining 2023.10.6 | AI Computer Vision 2023.10.6 | Insights 2023.10.6 | Apps 2023.10.6 |
| Document Understanding 2023.10.6 | Orchestrator 2023.10.7 | ||
| Test Manager 2023.10.6 | |||
Internal third-party component versions
For the Kubernetes versions that each Automation Suite version supports, see Kubernetes compatibility.
This Automation Suite release bundles the following internal components:
Component |
Version |
Istio |
1.23.0 |
| ArgoCD |
2.11.3 |
| Prometheus |
2.54.1 |
| Grafana |
11.1.5 |
| Fluentd & Fluent-bit |
logging-operator: 4.9.1 logging-operator-logging: 4.9.1 |
| Gatekeeper |
3.17.0 |
| Cert-Manager |
1.14.5 |
| Velero |
6.2.0 |
Migration tool version
The migration tool version you need depends on the standalone products you plan to migrate and the targeted Automation Suite version. For more details, see Migration compatibility matrix.
For instructions on migrating a standalone product to the current version of Automation Suite, see Full migration.
- Support for Amazon Linux 2023
- Introducing FQDN update procedure
- Improved migration to Automation Suite
- Bug fixes
- Known issues
- Log streaming does not work in proxy setups
- Licensing SQL connection error
- Insights dashboards excluded from backups
- Fluentd logs transmission failure
- Microsoft Entra ID limitations
- Cannot migrate between Automation Suite flavors when Apps is enabled
- Insights volumes created in two different zones following migration
- Failing EKS backup related to Velero version
- Upgrade failure due to overridden Insights PVC sizes
- Insights dashboards backup issue
- Test Automation SQL connection string is ignored
- Deprecation timeline
- Bundling details
- Product versions
- Internal third-party component versions
- Migration tool version
