- Automation Suite on Linux Release Notes
- Automation Suite on EKS/AKS Release Notes
Automation Suite release notes
Release date: January 23, 2025
This release applies a patch to Automation Suite 2023.10.7. The patch addresses some issues in Document Understanding. For more details, see the individual product release notes referenced in the Product versions section.
To apply this patch, follow the instructions in Applying a patch.
We recommend that you regularly check the deprecation timeline for any updates regarding features that will be deprecated and removed.
Product versions
To find out what has changed on each Automation Suite product, visit the following links.
If the product is greyed out, this new Automation Suite version does not bring any changes to it.
DISCOVER | BUILD | MANAGE | ENGAGE |
Automation Hub 2023.10.7 |
Automation Ops 2023.10.7 | AI Center 2023.10.7 | Action Center 2023.10.7 |
Task Mining 2023.10.7 | AI Computer Vision 2023.10.7 | Insights 2023.10.7 | Apps 2023.10.7 |
Process Mining 2023.10.7 | Document Understanding 2023.10.7-patch1 | Orchestrator 2023.10.8 | |
Test Manager 2023.10.7 | |||
Data Service 2023.10.7 |
Internal third-party component versions
This Automation Suite release bundles the following internal components:
Component |
Version |
RKE2 |
1.30.5+rke2r1 |
ArgoCD |
2.12.6 |
ceph |
17.2.6 |
rook-ceph |
1.14.6 |
prometheus-pushgateway |
1.10.0 |
cert-manager |
1.16.1 |
rancher-istio |
105.4.0-up1.23.2 |
rancher-monitoring-crd |
105.1.0-up61.3.2 |
rancher-gatekeeper |
104.0.1-up3.13.0 |
rancher-monitoring |
105.1.0-up61.3.2 |
longhorn |
1.6.3 |
longhorn-crd |
1.1.100 |
reloader |
1.0.95 |
csi-driver-smb |
1.16.0 |
velero |
1.14.1 |
redis-operator |
7.4.6-2 |
redis-cluster |
7.4.6-102 |
oauth2-proxy |
7.7.1 |
kube-logging/logging-operator |
4.9.1 |
config-reloader |
v0.0.5 |
