  • Automation Suite on Linux Release Notes
    • 2023.10.0
    • 2023.10.1
    • 2023.10.5
    • 2023.10.6
    • 2023.10.8
    • 2023.10.9
    • 2023.10.10
  • Automation Suite on EKS/AKS Release Notes
Automation Suite release notes
Last updated Sep 1, 2025
2023.10.7
Release date: December 18, 2024
New flags for enhanced Kerberos authentication
We have introduced new configuration flags to give you more control over the Kerberos authentication. You can now use the following flags to customize the Kerberos authentication settings:
  • kerberos_auth_config.enable_integrated_sql_auth: This flag allows you to decouple the Kerberos authentication from the SQL authentication login, and to enable or disable Kerberos authentication for SQL across all your products.
  • <serviceGroupName>.kerberos_auth_config.enabled: This flag allows you to control the use of Kerberos authentication for SQL authentication at product level. You must replace <serviceGroupName> with the name of your product.
These new flags bring changes to the priority order for SQL Kerberos authentication, as follows:
  1. Kerberos authentication for SQL is enabled by default when Kerberos authentication is enabled.
  2. If you set kerberos_auth_config.enable_integrated_sql_auth to false, Kerberos authentication for SQL is disabled across all your products.
  3. If you set <serviceGroupName>.kerberos_auth_config.enabled to false, Kerberos SQL authentication is disabled for the specified product.
For more details on Kerberos authentication, see Setting up Kerberos authentication.
New prerequisite checks
We have introduced more prerequisite checks to optimize the overall experience of installing and configuring Automation Suite and to catch missing requirements earlier. Here are some highlights:
  • A new validation check ensures that the READ_COMMITTED_SNAPSHOT option is enabled in the SQL Server database. We have implemented this check validation for Orchestrator, Apps, and Process Mining.
  • We have introduced a prerequisite check in the mirror-registry.sh and hydrate-registry.sh scripts to validate the OCI compliance of the external registry before uploading images.
Changes to the logs forwarding method
We have changed the logs forwarding method to external tools, such as Splunk, due to the switch to kube-logging. Now, you can forward logs to Splunk using the OpenTelemetry Collector.
Support bundle enhancements
We made the following improvements to the Automation Suite support bundle:
  • The support bundle now collects logs for the uipath-auth and velero namespaces.
  • The support bundle now captures custom resources.
Logging enhancement
Helm logs are now visible in the terminal output.
Security enhancements
We continue to provide security updates and patches to address Common Vulnerabilities and Exposures (CVEs).
Bug fixes
  • Erratum - added June 10, 2025: In multi-node (HA) setups where Grafana is deployed with two replicas, a lack of common data sources between the replicas caused issues in user session management. This resulted in errors such as Dashboard not found and Invalid dashboard UID in the request appearing in the Grafana dashboard. We have fixed this issue.
  • We have fixed an issue causing a side-by-side upgrade to fail in an offline environment when Apps was enabled.
  • We have fixed an issue that caused Insights data loss when you reinstalled or upgraded Insights following an Automation Suite upgrade from version 2023.4 or older.
  • We have fixed an Insights annotation issue that would block the Automation Suite installer.
  • We have fixed an issue that caused log collection for RKE2 system commands to run indefinitely.
  • We have fixed an issue causing the aicenter skill sync and aicenter skill status commands to fail during a side-by-side upgrade. This issue occurred due to a syntax error.
  • An issue was preventing exclude=rke2-* from being automatically added to the /etc/yum.conf file on all nodes. This issue occurred particularly in online environments and caused an unintentional upgrade of the RKE2 service on nodes other than the first server. Previously, you had to manually add the exception to the /etc/yum.conf on all nodes. We have fixed the issue.
  • We have fixed an issue causing unnecessary DNS resolution validation for redis.<primary-fqdn> and redis-db.<primary-fqdn> during Active/Passive prerequisite checks. This behavior no longer occurs.
  • We have fixed an issue that occurred in non-HA Redis scenarios, where the redis-cluster-0 pod could get stuck in a terminating state during node drain operations. This behavior no longer occurs.
  • When using style attributes in the HTML tags while customizing your Login page, they reflected accurately in the preview. However, upon saving the changes, the style attributes were deleted automatically. Now, all style attributes used within tags persist after saving your changes.
  • An issue was causing installation or upgrade failures when enabling Connaisseur during the configuration of an external OCI-compliant registry. This issue occurred when the registries.trust.enabled parameter was set to true in the cluster_config.json file. We have fixed the issue.
  • We have fixed an issue causing the upgrade to fail due to the overriding of existing Insights PVC sizes.
  • We fixed a bug that was breaking SAML2 when basic authentication was disabled, along with various other bugs.
Known issues
Task Mining Kerberos initialization failure
Erratum - added June 26, 2025: An issue causes the Task Mining service to fail to initialize in Kerberos environments. This issue occurs when the kerberos-discoverygroup-user-keytab secret is missing or when the discoverygroup app is not included in the enabledApps parameter of the IntegratedAuth app.
To address the issue, refer to the Troubleshooting section.
We fixed the issue in Automation Suite 2023.10.10.
Agent node addition failure in offline environments
Erratum - added June 26, 2025: An issue causes the addition process of agent nodes in offline environments to fail. Agent node additions require the temporary registry to be running. To address the issue, you must re-enable the temporary registry to successfully join the agent node.
Installation fails due to CA certificates with large policy OIDs
Erratum - added June 26, 2025: An issue causes the Automation Suite installation to fail when using Certificate Authority (CA) certificates that include a CertificatePolicies section with policy OID values exceeding 4 bytes. This issue prevents Automation Suite from recognizing these CA certificates, interrupting the installation process.
To address the issue, you must either ensure that the policy OID values within the CertificatePolicies section do not exceed 4 bytes, or avoid using CA generators that add the CertificatePolicies section to the certificates.
RKE2 custom configuration overwrite during upgrade
Erratum - added June 26, 2025: An issue causes the custom changes made to the RKE2 configuration file (/etc/rancher/rke2/config.yaml) to be overwritten during upgrades.
To address the issue, you must reapply your custom changes to the configuration file after each upgrade.
Licensing SQL connection error
Erratum - added June 26, 2025: Licensing SQL connection errors occur when the Data Source property specified both a named instance and a port.
RKE2 certificate rotation command issue on agent nodes
Erratum - added April 28, 2025: An issue causes the RKE2 certificate rotation command to run on the agent nodes even though it is not supported. This issue occurs during the Automation Suite upgrade process.
To address this issue, you must manually edit infra-installer.sh and replace the rke2 certificate rotate command with [[ ${NODE_ROLE} != "agent" ]] && rke2 certificate rotate to exclude the agent nodes.
This issue is fixed in Automation Suite 2023.10.8.
Kubernetes upgrade failure
Erratum - added April 15, 2025: An issue causes the Kubernetes upgrade to fail due to a missing certificate-injector-webhook in deployment.apps. To address the issue, you must run the following command:
kubectl delete configmap -n uipath-infra certificate-injector-webhook-configmap --ignore-not-foundkubectl delete configmap -n uipath-infra certificate-injector-webhook-configmap --ignore-not-found
We fixed the issue in Automation Suite 2023.10.9.
Document Understanding deployment issue post-upgrade
Erratum - added April 15, 2025: An issue prevents you from importing files into your DM session in AI Center after upgrading to Automation Suite 2023.10.x. This issue occurs due to the du-digitizer-worker deployment from the old Automation Suite version not being fully cleaned up after the upgrade. Starting with Automation Suite 2023.10.0, the deployment was renamed to du-digitizer-worker-deployment.
To address the issue, you must navigate to the ArgoCD UI and from the documentunderstanding application, manually delete the old du-digitizer-worker deployment. After deletion, re-sync the documentunderstanding application.
We fixed the issue in Automation Suite 2023.10.8.
Orchestrator database validation issue
Erratum - added April 15, 2025: An issue prevents the installer from automatically creating and validating the Orchestrator database. The issue occurs even though the sql.create_db parameter is set to true in cluster_config.json.
To address the issue you must manually edit /opt/UiPathAutomationSuite/UiPath_Installer/Prerequisite_Checks/scripts/validation.json and set advancedDbConfig.connectionStringParameter to "", under "service": "orchestrator", as shown in the following example:
"advancedDbConfig": [{
        "dbName": "AutomationSuite_Orchestrator_test",
        "connectionStringParameter": "",
        "optionalCommands":["ALTER DATABASE AutomationSuite_Orchestrator SET READ_COMMITTED_SNAPSHOT ON;"]
      }]"advancedDbConfig": [{
Incomplete Docker registry cleanup process
Erratum - added April 15, 2025: An issue prevents the registry cleanup command from effectively clearing the unused Docker images from all registry pods. To address the issue, refer to the Troubleshooting section.
Upgrade fails due to MongoDB to SQL Server migration
Erratum - added April 15, 2025: We have identified an issue impacting the side-by-side and the in-place upgrade of Automation Suite 2022.10 or earlier to Automation Suite 2023.10.0 or later. Due to a faulty migration from MongoDB to SQL Server, the upgrade operation fails if you have Apps enabled and use Kerberos authentication for the SQL Server database.
The recommended solution is to upgrade to Automation Suite 2023.10.9.
Kube-proxy health check not working
Erratum - added April 15, 2025: The node-monitor component, which monitors the node for issues such as checking kube-proxy health or if ip_forward is enabled, and cordons the node if issues arise, is not working for specific nodes such as GPU, task-mining, or as-robot. We have fixed this issue in Automation Suite 2023.10.9.
Kerberos tickets do not automatically renew
Erratum - added April 15, 2025: Kerberos tickets fail to automatically renew after cluster restoration, requiring manual sync of the Windows Auth app.
This issue is fixed in Automation Suite 2023.10.9.
Service upgrade fails during pre-service script execution
Erratum - added April 15, 2025: While you upgrade from older versions to 2023.10.x, the service upgrade script can abruptly end with non-zero exit code. This issue occurs when one of the pre-upgrade script, namely scale-down-insights-looker-deployment.sh, fails in certain scenarios. To address this issue, refer to .
The issue is fixed in Automation Suite 2023.10.9.
Same requirement for enabling user and SQL authentication
Erratum - added March 24, 2025: The configuration of user authentication and SQL authentication for the Automation Suite cluster is interconnected. To use either of them, currently you must set both kerberos_auth_config.enabled and kerberos_auth_config.enable_integrated_sql_auth parameters to true.
AI Center storage migration failure
Erratum - added February 13, 2025: An issue prevents uipathctl from correctly setting executeMigration to true during the migration process from Ceph in-cluster storage to external object storage in AI Center.
To fix this issue, you must manually set executeMigration to true in ArgoCD for AI Center and then proceed with a resync, ensuring to prune. This issue is fixed in Automation Suite 2023.10.8.
Email alerts configuration failure post upgrade
Erratum - added February 13, 2025: An issue affects the functionality of email alerts configuration and the setup of multiple receivers after upgrading from Automation Suite 2022.10. To address this issue, see Troubleshooting.
FQDN update failure
Erratum - added February 13, 2025: An issue causes the FQDN update to fail due to the update_fqdn parameter to not being properly set in the service-cluster-configurations secret.
To address this issue, you must manually remove the update_fqdn and update_fqdn_state parameters and update the service-cluster-configurations secret using the following command:
kubectl patch secret service-cluster-configurations -n uipath-infra --type=json -p='[
  {"op": "remove", "path": "/data/UPDATE_FQDN"},
  {"op": "remove", "path": "/data/UPDATE_FQDN_STATE"}
]'kubectl patch secret service-cluster-configurations -n uipath-infra --type=json -p='[
Deprecation timeline
We recommend that you regularly check the deprecation timeline for any updates regarding features that will be deprecated and removed.
Bundling details
Product versions
To find out what has changed on each Automation Suite product, visit the following links.
If the product is greyed out, this new Automation Suite version does not bring any changes to it.
DISCOVERBUILDMANAGEENGAGE
AI Center 2023.10.7Action Center 2023.10.7
Task Mining 2023.10.7AI Computer Vision 2023.10.7Insights 2023.10.7Apps 2023.10.7
Document Understanding 2023.10.7Orchestrator 2023.10.8
  Test Manager 2023.10.7
Internal third-party component versions
This Automation Suite release bundles the following internal components:
Component
Version
RKE2
1.30.5+rke2r1
ArgoCD
2.12.6
ceph
17.2.6
rook-ceph
1.14.6
prometheus-pushgateway
1.10.0
cert-manager
1.16.1
rancher-istio
105.4.0-up1.23.2
rancher-monitoring-crd
105.1.0-up61.3.2
rancher-gatekeeper
104.0.1-up3.13.0
rancher-monitoring
105.1.0-up61.3.2
longhorn
1.6.3
longhorn-crd
1.1.100
reloader
1.0.95
csi-driver-smb
1.16.0
velero
1.14.1
redis-operator
7.4.6-2
redis-cluster
7.4.6-102
oauth2-proxy
7.7.1
kube-logging/logging-operator
4.9.1
config-reloader
v0.0.5
Migration tool version
The migration tool version you need depends on the standalone products you plan to migrate and the targeted Automation Suite version. For more details, see Migration compatibility matrix.
For instructions on migrating a standalone product to the current version of Automation Suite, see Full migration.
