uipathctl reference guide
Last updated Feb 24, 2025
uipathctl reference documentation
Controls the UiPath® Automation Suite deployment
uipathctl [flags]uipathctl [flags]
Options
-h, --help            help for uipathctl
--timeout duration    timeout of the command (default 1h0m0s)--context string      name of the kubeconfig context to use
  • uipathctl reference documentation
  • Description
  • Options
