- Overview
- Pre-installation
- Cluster administration
- uipathctl cluster
- uipathctl cluster migration
- uipathctl config argocd
- uipathctl version
- Backup and restore
- uipathctl snapshot
- uipathctl snapshot backup
- uipathctl snapshot delete
- uipathctl snapshot list
- uipathctl snapshot restore
- Certificate management
- Upgrade
- Authentication
- Monitoring and alerting
- Troubleshooting
uipathctl reference guide
Last updated Feb 24, 2025
The following command executes the cluster migration from a source cluster to a target cluster.
There are two stages of the migration process:
Kubernetes objects are migrated from the source cluster, followed by the installation on the target cluster.
The input and version files are used to configure the migration process.
uipathctl cluster migration export [flags]
# Export the cluster state from source cluster to a local directory
uipathctl cluster migration export --output-dir /tmp/cluster-source
-h, --help help for export
--output-dir string path to output directory
