- Overview
- Pre-installation
- Cluster administration
- uipathctl cluster
- uipathctl cluster migration
- uipathctl config argocd
- uipathctl version
- Backup and restore
- uipathctl snapshot
- uipathctl snapshot backup
- uipathctl snapshot delete
- uipathctl snapshot list
- uipathctl snapshot restore
- Certificate management
- Upgrade
- Authentication
- Monitoring and alerting
- Troubleshooting
uipathctl reference guide
Last updated Feb 24, 2025
Get the current Orchestrator custom config in
pem
format.
The command defaults to the current context in the
kubeconfig
file. If the --kubeconfig
flag is set, it uses the kubeconfig
file specified by the flag.
uipathctl config orchestrator get-config [flags]
# Get the current orchestrator custom config from the cluster
# Get the current orchestrator custom config from the cluster identified by the current context in the kubeconfig file
uipathctl config orchestrator get-config --kubeconfig cluster.kubeconfig
