Automation Suite admin guide
Last updated Aug 22, 2025
Deallocating user licenses
Note: The information on this page refers to options that are only applicable if user license management is enabled for your organization.
Deallocating directly assigned licenses
For licenses that have been directly assigned to a user, you must edit the user to remove the license.
  1. Go to Admin and select the organization at the top of the panel on the left.
  2. Select Licenses.
    The Licenses page for the organization opens on the Users tab.
  3. At the bottom of the page, select License Allocations to Users to expand the section.
  4. Optionally type in the search box to find the user from which you want to deallocate licenses.
  5. At the right end of the row, select the Edit license allocation icon:
    The Edit License Allocation panel opens at the right of the window.
  6. Clear the checkboxes for licenses that you want to deallocate.
  7. Select Save at the bottom of the panel to apply your changes.
Preventing a user from acquiring a license
If you want to prevent a user from acquiring any license, either inherited from a group or allocated directly:
In the Edit License Allocation panel, select the Allocate to User option and clear all the checkboxes.
Deallocating licenses inherited from groups
Editing the group allocation rule
Note: Editing the license allocation rule of a group changes the licenses of all group members.
  1. Go to Admin > Organization > Licenses.
  2. At the bottom of the page, select License Allocations to Groups to expand the section.
  3. Optionally type in the search box to find the group.
  4. At the right end of the row, select the Edit group allocation rule icon.
    The Edit Group Allocation Rule panel opens at the right of the window.
  5. Select or clear checkboxes so that only those for the licenses you want group members to have are selected.
  6. Select Save at the bottom of the panel to apply your changes.
The licenses for all group members are updated according to your changes.
Releasing the license
Note: Releasing a user's license does not prevent the user from re-acquiring it the next time they log in.
  4. At the right end of the row, select the Group members with license inheritance icon.
    The License inheritance from group panel opens at the right of the window.
  5. For the user whose license you want to release, select Release license.
Removing a user from a group
Important: Apart from removing their license, removing a user from a group also removes the roles and robot configuration they inherited from the group.
  1. Go to Admin > Organization > Accounts & Groups page.
  2. Select the Groups tab.
  3. At the right of the row, select the Edit icon.
    The Edit Group panel opens at the right of the window.
  4. Remove the user from the Add names field.
  5. Select Save at the bottom of the panel.
