- Getting started
- Host administration
- Organizations
- About organizations
- Managing organization administrators
- Managing organization settings
- Authentication and security
- Licensing
- Tenants and services
- Accounts and roles
- External applications
- Testing in your organization
- Notifications
- Logging
- Troubleshooting
Automation Suite admin guide
Organization settings are broadly-applicable and impact everyone who the UiPath platform. Settings can impact all tenants, all services, and all users, except where options exist to customize more granularly.
If you are an organization administrator, you can access the Admin space, which includes the organization settings.
To access organization settings
From the App launcher (top left corner), select Admin. You are then redirected to the organization settings page.
If you are already browsing the Admin pages, select your organization name at the top of the panel on the left:
Changing the URL
Account Logical Name) greatly impacts the entities that used the previous URL.
- Robots configured at the services level are disconnected. If you change the URL, you need to reconnect your robots , entering the new URL.
- Bookmarks containing the organization URL don't work anymore. You must send the new URL to your users.
- Mobile Orchestrator users are disconnected. Send them the new URL to connect again.
After Changing Your Site URL
The URL is also known as your Account Logical Name or organization-specific URL. Changing the URL greatly impacts the entities that were using the previous URL:
- Robots configured at the service level are disconnected. If you change the URL, you need to reconnect your robots, entering the new URL.
- Bookmarks containing the organization URL don't work anymore. You must share the new URL with all your users.
You can change the language either globally, with the change being propagated to all the users accessing your organization, or at a local level, for yourself only. The default language is English.
In some cases, you might need to refresh the page or log out and then log back in so that all elements on the page are localized.
Global language settings
You can change the language used for system emails sent by Automation Suite and other services to your users.
If a service has a different language setting for system emails, that setting takes precedence.
User language settings
Each user can localize the user interface for themselves by selecting the desired language from the Preferences page. For details, refer to Selecting the user language.
For details about the supported languages across our products, refer to Localization Support .
The Support ID is only available if Automation Suite is licensed.
To view your support ID:
Go to Admin, select the organization in the left pane, and then Settings. The support ID is visible in the top right corner of the page. Select the copy icon
to copy your support ID.
You can display your own company logo in the header:
To add your logo
The appropriate logo for your current theme appears in the header.
User license management allows you to get more out of user licenses because one license can be used across all tenants. When this setting is disabled, user licenses are bound to the tenant to which they are allocated.
For more information about this option, refer to User license management.
