Last updated Nov 13, 2025
Using the Automation Suite support bundle
The Automation Suite support bundle collects application-level logs of UiPath® services and and relevant objects required to evaluate and fix the problem. The Automation Suite support bundle also contains historical logs you can use to analyze patterns when troubleshooting a problem. Historic logs are particularly helpful when the potential root cause of an issue is not evident just by looking at the state of the cluster.
The Automation Suite support bundle is also needed when asking for guidance or a fix from the UiPath® Support team as they need it for analysis purposes.
Note:
The Automation Suite support bundle does not collect or store any PII or confidential data of you, your user, or your automation. UiPath® applications not not leak or log any confidential information in their records. At the platform level, the log collector is designed to mask any such critical information.
Automation Suite Support Bundle Tool parameters
  • High-level summarized usage and configuration telemetry is also exported with this tool generating an XML file. This telemetry includes:
    • Automation Suite installation configuration details (such as Kubernetes flavor, installation mode, version, and enabled services, among other settings).
    • Cluster-level resource usage information (such as CPU and memory availability and utilization, among other metrics).
    • UiPathctl command execution details (such as status, logs, and duration, among other details).
    • Usage telemetry:
      • Robot execution duration per month by robot type.
      • Robot concurrency - the maximum number of robots that executed at the same time.
      • Metrics on jobs run, processes run, queue items, job failure rate, and users.
      • Environment information.
      • AI Units usage summary if you use AI Center.
  • UiPath uses this data only for internal reporting to strengthen customer understanding and improve the quality of support and overall experience.
  • You can upload the XML file in the Customer Portal to share your high-level self-hosted usage telemetry with the UiPath Support team.
  • You can stop generating summarized telemetry by adding service-metrics to the exclusion list with the --exclude=service-metrics option. This option is available in Automation Suite 2.2510 and later.
Generating the support bundle
To generate the support bundle, run the following command from the installer directory:
./bin/uipathctl health bundle cluster_config.json --versions versions/helm-charts.json./bin/uipathctl health bundle cluster_config.json --versions versions/helm-charts.json
This tool requires some time to gather and store all the logs in a temporary location on your local or management machine.
The following table lists the optional flags that you can use for the support bundle tool:
Flags
--output-dir string
Specify the directory to store the support bundle.
--namespace string
Specify the namespace where UiPath Automation Suite is deployed.
--include string
Specify additional components (comma separated) to include in the bundle (such as --include=historical-logs).
--exclude string
Specify components (comma separated) to exclude from the bundle (such as--exclude=rke2-bundle or --exclude=service-metrics).
--from YYYY-MM-DD
The start date to collect the historical logs in YYYY-MM-DD format.
--days int
The number of days from the start date for which to collect the historical logs.
--limit-bytes int
Limits the size of the logs of running pods by providing the integer value in bytes.
By default, if the --from flag is not specified, then the historical logs will be collected for the past 2 days starting from today, irrespective of the --days specified. If the --from is specified and --days is not specified, then the historical logs will be collected for 2 days starting from the specified start date.
The RKE2 bundle is included by default in the support bundle. To exclude it, use theflag --exclude=rke2-bundle.
The historical logs are not included by default in the support bundle. To include them, use the flag --include=historical-logs.
Automation Suite Support Bundle Structure
The .tar.gz archive contains following files and folders:
File/folder
logs
Contains the historical logs collected from ceph or external object store.
current-logs
Contains the live logs (such as logs for current and previous instance of pods).
events.json
Contains the event descriptions from all the namespaces.
alerts
Contains the active prometheus alerts in the cluster.
server0.tar.gz, server1.tar.gz, ...
Contains the RKE2 bundle for every node in the cluster.
namespace/resource/object.yaml
Contains the object descriptions for the server-preferred/custom namespace and cluster-scoped resources.
service-metricsContains high level configuration and usage telemetry stored in individual XML files.
The RKE2 bundle structure is as follows:
Directory
systemlogs
Contains the logs related to system events, security audits, and general system messages.
systeminfo
Contains the information about the running processes, disk usage, cpu utilisation and so on.
etcd
Contains the information related to the data storage of the etcd key-value store.
journald
Contains the logs managed by systemd-journald.
networking
Contains the network configuration details such as iptables, routing and so on.
rke2
Contains the kubelet logs, agent and server certificates, info on crictl and the resources running on the cluster and the pod logs.
