- Overview
- Requirements
- Deployment templates
- Step 2: Configuring the OCI-compliant registry for offline installations
- Step 3: Configuring the external objectstore
- Step 4: Configuring High Availability Add-on
- Step 5: Configuring SQL databases
- Step 7: Configuring the DNS
- Step 8: Configuring the disks
- Step 9: Configuring kernel and OS level settings
- Step 10: Configuring the node ports
- Step 11: Applying miscellaneous settings
- Cluster_config.json Sample
- General configuration
- Profile configuration
- Certificate configuration
- Database configuration
- ArgoCD configuration
- Kerberos authentication configuration
- AI Center-specific configuration
- Monitoring configuration
- Cluster administration
- Managing products
- Migrating Redis from in-cluster to external High Availability Add-on
- Migrating from in-cluster registry to an external OCI-compliant registry
- Scaling a single-node (evaluation) deployment to a multi-node (HA) deployment
- Monitoring and alerting
- Migration and upgrade
- Upgrading Automation Suite
- Executing the upgrade
- Troubleshooting
- How to clear Redis data
- How to enable Istio logging
- How to check the TLS version
- How to schedule Ceph backup and restore data
- Temporary registry installation fails on RHEL 8.9
- Frequent restart issue in uipath namespace deployments during offline installations
- DNS settings not honored by CoreDNS
- RKE2 not getting started due to space issue
- In-place upgrade timeouts
- ArgoCD login failed
- Redis probe failure
- RKE2 server fails to start
- Mismatch in reported errors during diagnostic health checks
- No healthy upstream issue
- Redis startup blocked by antivirus
- Exploring Logs
- Exploring summarized telemetry
Last updated Nov 13, 2025
Generate the latest cluster_config.json file using the following command:
./bin/uipathctl manifest get-revision >> ./cluster_config.json./bin/uipathctl manifest get-revision >> ./cluster_config.jsonNote: For details on how to configure the cluster_config.json parameters, see Advanced installation experience.
Update the following section in the
cluster_config.json file with the new access_key, secret_key or acount_key and account_name:
"external_object_storage": {
"enabled": false, // <true/false>
"create_bucket": true, // <true/false>
"storage_type": "s3", // <s3,azure,aws>
"fqdn": "", // <needed in case of aws non instance profile>
"port": 443, // <needed in case of aws non instance profile>
"region": "",
"access_key": "", // <needed in case of aws non instance profile>
"secret_key": "", // <needed in case of aws non instance profile>
"use_managed_identity": false, // <true/false>
"bucket_name_prefix": "",
"bucket_name_suffix": "",
"account_key": "", // <needed only when using non managed identity>
"account_name": "",
"azure_fqdn_suffix": "core.windows.net",
"client_id": "" // <optional field in case of managed identity>
},"external_object_storage": {
"region": "",
"account_name": "",
},To run the installer, use the following command:
cd /opt/UiPathAutomationSuite/{version}/installer
./bin/uipathctl manifest apply ./cluster_config.json --versions versions/helm-charts.jsoncd /opt/UiPathAutomationSuite/{version}/installer
