Last updated Nov 13, 2025
Quick links
Before you begin
Step
Details
Find out the essentials on Disaster Recovery - Active/Passive and Active/Active deployments
Learn more on the architecture of Disaster Recovery - Active/Passive and Active/Active deployments
Frequently asked questions
Make sure you meet the hardware and software requirements.Disaster recovery - Active/Passive requirements
Installing a new Automation Suite setup
Step
Details
Install the primary server
Generate the cluster_config.json file using the interactive installer.
Update the cluster_config.json file.
Resume the installation.
Install the secondary server
Copy or generate the cluster_config.json from the primary server.
Note:
For Active/Passive configurations, make sure to switch off the products in the passive cluster. For details, see Switching off inactive products.
Converting an existing setup
Step
Details
Converting an existing installation to a Disaster Recovery - Active/Passive setup
Convert the standalone Automation Suite cluster into the primary cluster
Install secondary Automation Suite cluster.
Switching to the secondary cluster
N/A
Performing post-installation operations in a Disaster Recovery - Active/Passive deployment
N/A
Upgrading an Active/Passive deployment
N/A
Backing up and restoring an Active/Passive deployment
N/A
  • Before you begin
  • Installing a new Automation Suite setup
  • Converting an existing setup
