test-suite
- Getting Started with Test Suite
- Studio
- Orchestrator
- Testing robots
- Test Manager
Capabilities
Test Suite User Guide
Last updated Dec 18, 2024
Capabilities
The Capabilities section provides a snapshot of the features and capabilities that UiPath® Test SuiteTM offers for seamless and powerful software and RPA testing:
- API Test Automation: UiPath® enables you to automate the process of API testing, validating the performance and security of your APIs, which is vital for seamless communication between different software applications.
- Test Data Management: Manage your test data effectively with our test suite. It allows you to create, modify, and manage data needed for your tests, ensuring accuracy and efficiency in your test runs.
- RPA Testing & Application Testing: Test your RPA workflows and application performance with our range of testing tools, to ensure they function correctly and effectively.
- Mobile Test Automation: Validate the functionality of your mobile applications with our mobile test automation capabilities. Test across different devices and operating systems to ensure a smooth user experience.
- Test Reporting & Analytics: Generate detailed reports and visual analytics from your test results. These insights can help you understand the performance of your applications and identify areas for improvement.
- Integrations (ALM, CI/CD): Integrate your testing workflow seamlessly with Application Lifecycle Management (ALM) and Continuous Integration/Continuous Delivery (CI/CD) pipelines for automated and streamlined operations.
- SAP Testing: Specialized tools for testing your SAP software. Ensure your SAP applications are running at peak performance with detailed testing.
- Test Execution: Efficiently run tests and get reliable results.
- Manual Testing: Perform hands-on, exploratory tests with our tools designed to make manual testing effective and efficient.
- Migration: Migrate your testing processes and data easily with our tools. No matter the platform you're coming from, we help smooth your transition.
- AI-powered testing: employ generative AI features to streamline and simplify your testing process.
