- Getting Started with Test Suite
- Studio
- Test Suite - Studio
- Overview
- Testing activities and coded automation APIs
- About the mobile device automation architecture
- Getting started
- Managing mobile device manager
- Managing applications
- Creating mobile automation workflows
- Device Interaction
- Automation for React Native apps
- Mobile automation activities and coded automation APIs
- Orchestrator
- Testing robots
- Test Manager
Test Suite User Guide
This section includes testing related activities and coded automation APIs found in the UiPath.Mobile.Automation.Activities package. Through these activities and coded automation APIs, you can create automations for your devices, running native or web applications.
mobileautomation
service, downloaded with the Mobile.Automation package. Visit Mobile Automation coded automation APIs to
check how to use the Mobile Automation coded automation APIs.
This section includes all activities related to mobile automation found in the Mobile.Automation package.
Activity |
Description |
Establishes a connection to a mobile device and provides scope for all subsequent activities/coded automation APIs. | |
Retrieves the log types from a device connected via the Mobile Device Connection. | |
Retrieves the logs from a mobile device connected via the Mobile Device Connection scope activity. | |
Installs a specified app on a mobile device connected via the Mobile Device Connection. | |
Retrieves the page source from a mobile device connected via the Mobile Device Connection scope activity. | |
Manages the current app by using a user input command. | |
Sends a user input command to a specified app on the target mobile device. | |
Navigates to a deep link inside an application. | |
Opens a specified URL in the currently active web browser. | |
Retrieves the current orientation of the specified mobile device. | |
Presses a hardware button on the connected device. | |
Changes and then retrieves the orientation of the connected device. | |
Takes a screenshot of the screen of the mobile device you are using with custom dimensions specified in the Height and Width properties. | |
Returns a boolean variable that states whether a specified UI element exists. | |
Retrieves an attribute of a specified UI element. | |
Retrieves the selected item from a target UI element. | |
Extracts the text from a specified UI element and returns it as a string variable. | |
Sets the selected item on a target UI element. | |
Types the specified text into a target UI element. | |
Swipes the screen in a specified direction and for a specified amount of times. | |
Directional Swipe | Perform a swipe operation with the following pre-defined directions: Down, Up, Left, Right. |
Draw Pattern | Draws a path marked by multiple points on the device screen. |
Type Text | Takes the content typed through the keyboard and pastes it into the currently active UI element. |
This section includes all coded automation APIs related to mobile automation found in the Mobile.Automation package.
Coded automation API | Description |
Connect/ConnectAsync | Connects a device to an application. |
CreateApplication | Creates a new application and give it a name. |
CreateDevice | Creates a new device. You can use this device in code but it will not be saved in Mobile Device Manager. |
GetApplication/GetApplications | Gets the application with the specified name (with the same configurations present in Mobile Device Manager). |
GetDevice/GetDevices | Gets the device with the specified name (as you configured it in Mobile Device Manager). |
DirectionalSwipe | Perform a swipe operation with the following pre-defined directions: Down, Up, Left, Right. |
DrawPattern | Draws a path marked by multiple points on the device screen. The points that create the path are recorded from the path of the finger on the device screen. You can add multiple finger paths to simulate screen interactions that involve multiple fingers. |
ElementExists | Returns a boolean variable that states whether a specified UI element exists. |
ExecuteCommand | Execute native mobile commands that are not associated with a specific endpoint. For example, you can retrieve the battery info or dismiss alerts (see Appium Commands). |
GetAttribute | Retrieves an attribute of a specified UI element. |
GetDeviceOrientation | Retrieves the current orientation of the specified mobile device. |
GetLogTypes | Retrieves the log types from a device connected via the mobile device Connection. |
GetPageSource | Retrieves the page source from a mobile device connected via the Connection class. |
GetSelectedItem | Retrieves the selected item from a target UI element. |
GetSesstionIdentifier | Retrieve the session ID of the current Mobile Device Manager connection to route HTTP commands to Appium endpoints so you can perform custom actions. |
GetSystemTime | Retrieves the current time of the device. |
GetText | Extracts the text from a specified UI element and returns it as a
String variable.
InstallApp | Installs a specified app on a mobile device connected via
Connection .
ManageCurrentApplication | Resets or launches the current app for this session. |
ManageOtherApplication | Manages other applications using commands. |
OpenDeepLink | Opens a deep link inside an application. |
OpenUrl | Opens a URL in Chrome. The current active application should be Chrome, having at least one opened tab, before calling this method. |
PositionalSwipe | Swipes to a predefined location on the screen with starting and ending points. |
PressHardwareButton | Presses a hardware button on the connected device. |
SaveLogs | Save logs of a specific type to a file. |
SetDeviceGeoLocation | Sets the current geo-location of the device. |
SetDeviceOrientation | Changes and then retrieves the orientation of the connected device. |
SetSelectedItem | Sets the selected item on a target UI element. |
SetText | Types the specified text into a target UI element, recognized by Mobile Automation. |
Swipe | The swipe operation iterates through multiple swipes on the list (up to MaxNumberOfSwipes) until it locates the specified element. If the Target is not set, the swipe operation performs a single swipe without searching for a specific element. |
TakeScreenshot | Takes a screenshot of the screen of the mobile device you are using with custom dimensions. |
Tap | Returns a boolean variable that states whether a specified UI element exists. The coded automation API doesn't have a return value, but if the specified UI element exists (boolean value), then it performs tap operations on it. |
TypeText | Takes the content typed through the keyboard and pastes it into the currently active UI element. To paste the text inside the element that you want, you need to focus wherever on the UI where you want to paste the text. You can use this coded automation API when automating applications for which you need to type text through the keyboard, but without a target element that is recognized by Mobile Automation. |
