test-suite
Test Suite User Guide
Last updated Jul 25, 2025
Deleting test case results
If you have deleted test cases that were previously executed, and generated test case results or logs, you can delete the corresponding test executions. Deleting the corresponding test executions ensures the test results of your project are up to date. Follow these steps to delete the test case logs associated with deleted test cases:
  1. In your Test Manager project, go to the Executions section.
  2. In the View by dropdown list, select Test Set.
    This groups test results based on test set executions.
  3. Locate and select the test executions containing the test case logs you want to delete.
  4. Select Delete.
Important: Deleting a test execution also deletes all associated test case logs. Test case logs unrelated to deleted test cases will also be deleted, as they are part of the selected test execution.
