test-suite
- Getting Started with Test Suite
- Studio
- Test Suite - Studio
- Overview
- Testing activities and coded automation APIs
- Orchestrator
- Testing robots
- Test Manager
Applying filters and views
Test Suite User Guide
Last updated Jul 25, 2025
You can apply filters and store them in views for your test objects. Depending on the scope of a view (personal or public), you can persist the view containing the filters for a user or for all users within the project.
The available filters that you can apply are similar to the ones that appear in the
Columns type of that section, consisting of:
- Properties native to a test object (such as Labels, Updated by, Source, and others)
- Custom labels
Follow these steps to customize your filters and view:
- Go to the desired test object section (i.e. Requirements) and select Filters.
- Select Add filter to
choose the filters that you want to apply.
When you select the filter, also select the value that you want it to have.
- Select Apply to include the filters in your view.
- To save these filters as a view, select Views, and then Save view.
- In the Save view window, choose to create a New view or Update
an existing view with the filters.
Decide whether to keep the new view private or set it to Public for other users to access.
- Select Save to confirm changes.
- To apply a view that you created,
select Views, and then Open views.
- Choose a personal view
(My views) or a Public view.
You can also change the visibility of your created views between private and public, according to your needs.
- Select the desired view and select Open to apply.
