test-suite
- Getting Started
- Studio
- Orchestrator
- Testing robots
- Test Manager
Testing parameters with test variants
OUT OF SUPPORT
Test Suite User Guide
Last updated Nov 11, 2024
In this scenario, you can learn how to use the input and output parameters to provide execution data between different scripts, and test parameters with test variants.
To create define test parameters and add test data variations, follow these procedures:
To provide execution data between different scripts, you can define test parameters in Studio. For example, your test case contains Material Number and Quantity, and you want to test the Sales Order creation for different materials and quantities.
- In the SAP GUI, double-click the SAP Fiori Launchpad to open the work center framework.
- Navigate to Project and Process Management > Solution Documentation > Business Processes.
- Go to the business process that contains the test case you are looking for.
- Find your test case and click Test Configuration.
- Navigate to Go to > Expert Mode.
- Switch to Change Mode.
- Go to the Variants tab to add a variant.
- Fill in the corresponding test data.
- Click Save to confirm changes.
- Click Execute to start execution.
To view the test execution logs, click the Log button within the test automation overview window.
