test-suite
- Getting Started
- Studio
- Orchestrator
- Testing robots
- Test Manager
Xray for Jira
OUT OF SUPPORT
Test Suite User Guide
Last updated Nov 11, 2024
Xray for Jira
The Xray Test Management for Jira integration provides an alternative to managing your tests using the Test Manager. To take advantage of this, you need to install the Jira connector and complete the integration by configuring a new connection in the Test Manager.
- Jira Server account
- UiPath Test Manager for Jira v1.0.5
- Log in to Jira as an administrator.
- Navigate to Settings > Manage Apps.
- Go to Find new apps.
- Use the search bar to find UiPath Test Manager for Jira.
- Click Install to add the app to Jira.
- Log in to the Test Manager as an administrator.
- Open your project.
- Click the Settings button to open Project Settings.
- In the Integration list, click an Xray connection to expand the panel.
- Click Edit to configure the connection.
- Click Save to confirm.
Deleting the connection removes all associated requirements and test cases.
- Click Delete to remove the connection.
- Click Ok to confirm.
The tests executed through the Orchestrator propagate the results to Xray. For more information on managing tests using Xray, see the Xray Documentation Home.
Important:
- Test cases edited in the Test Manager are not synchronized with Xray. Conversely, changes made to test cases in Xray are reflected in the Test Manager.
Related articles
